Question about Casablanca Fan 3245T Ceiling
This is actually a Delta II model fan. The fan blades and the ring they are bolted to recently dropped out of the fan housing and are sitting on top of the base of the light kit. Is this the flywheel? If not what broke and can it be fixed at home?
It is the flywheel. I ordered one directly from the Casablanca web site, took the fan down and find the parts are pressed together. Looks like it needs some heavy tools or a jig of some kind. Any suggestions?
Posted on Jul 09, 2008
Their website says you need special tools to get the flywheel off. they offer to repair it for $110. I took my fan down and discovered the flywheel is also broken. The hub of the flywheel looks like it is pressed on so a puller of some kind is probably needed. you can probably heat the old flywheel with a torch or heat gun to expand it enough to get it off, but that does not mean the new one will go on easily.
How to replace 0 ring on a Delta (brizo) single handle Kitchen faucet model # 61600 SS170?
TAKE IT APART. LOOK FOR SMALL SET (ALLEN) NUT/BOLT OR REGULAR NUT/BOLT YOU CAN TAKE OFF THEN TAKE OFF HANDLE AND REPLACE THE O RING.
Oct 08, 2014 | Delta Plumbing
How to change the thermostat on 1981 gold wing
The thermostat housing sits above the timing belt cover at the front of the engine right dead center. The housing extends rearward beneath the intake manifold and then crosses over from the mid point to each of the cylinder heads. The Thermostat itself is contained in the housing at the very front where the upper radiator hose drops down and attaches to the housing.
The thermostat cover is held on by two bolts, each one accessible from either side of the motorcycle if you remove the lower skirts to the main fairing.. Would recommend at least loosening the radiator to gain a little more access.
There is a large o-ring which must be replaced. Never reuse old flattened o-rings. This cover also contains the Thermostat switch for the Fan, also sealed with an o-ring. The Sending unit for the temperature gauge is on the is on the main housing again sealed with an o-ring. If yu have any issues with the fan not coming on when it should, or the temp gauge not indicating correctly, now would be the time to address those issues while you are in there.
You will need to drain the cooling system first. If the Anti-freeze has recently (less than 6 months ago) been drained and replaced then you can reuse it. otherwise, when you refill the system, always use fresh antifreeze mixed 50/50 with distilled water.
After refilling, run the bike, get it up to temprature, wait for the fan to com one, and then shut it off. Let it cool off, and then add more coolant as needed. Trapped air will have come to the top of the radiator. Top off and check the reservoir tank and fill it to the upper level indicated. Do not over fill.
Have fun !!
Jun 26, 2014 | 1981 Honda GL 1100 Innerstate Gold Wing
I am looking for all the screws and bolts for delta martine II
You might be able to substitute standard hardware but this will require some trial and error locating the correct parts in the correct sizes.
Dec 27, 2013 | Delta Martine Crib
Severe vibration during operation of dometic b3300 air con
If this started after the new fan was installed,then the housing the fan sits in is not secure.Or the fan blade is out of balance which means you will need a new fan blade.
Check that all nuts and bolts are tight.If there is a belt be sure it is not worn or missing pieces.
Nov 03, 2011 | Heating & Cooling
Trying to remove the Hunter Stratford II 52" ceiling fan. The canopy ring rotates approximately 1/4 turn but does not release.
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/41803.pdf
Page 8 of the model 20761 Hunter ceiling fan shows how to remove the canopy trim ring. Ours had double stick tape holding the brushed nickel to a plastic trim ring. Dropped it, then squeezed the plastic ring.
Sep 19, 2011 | Hunter 20761 52'' The Stratford II Brushed...
Looks like the oil is leaking out right above the
oil filter screws onto an adapter housing which also has the pressure sending unit on it (above oil filter). This adapter housing bolts to the block with 3 bolts. if oil appears to be leaking from where the adapter housing meets the block (especially at the rear side of engine near bottom), then you need to replace the siamese o-rings between the adapter housing and the block ($12 part at dealer). remove lowest 12mm bolt and loosen top 2 12 mm bolts(top 2 bolts won't come out unless you drop the engine down, but loosening 1 inch is all you need), replace o-rings and retighten bolts. be careful not to get dirt/grit between block and adapter. just finished doing this to son's 95 2.7 v6 which was leaving an 8" puddle of oil after idling for only 1 minute-worked perfect
Feb 24, 2010 | 1995 Honda Accord
How do i clean my tower aloha breeze fan
you have to remove the fan housing. it is usually screwed.
Sep 10, 2009 | Tower Aloha Breeze Fan
We have a hampton bay fan and can not get it off the ceiling how do you remove it?
I have no experience with ceiling fans and for me removing the housing didn't get me anywhere. For our fan (Model 23758) there was a nearly invisible ring of material at the base of the fan where it meets the ceiling. This was in place for apparently aesthetic purposes as it hid the screws that secured it to the ceiling bracket. By rotating this ring and pulling down, we were able to to remove it.
Jun 30, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Motor problem
hi,
I wrote to a person earlier about oiling one, now Im thinking she may be having the same problem you have, I will paste that info at the bottom, but sounds like your fan blade assembly has come loose and/or worked its way back down to the motor, study the fan blade assembly and look for an allen bolt or ring holding the assembly to the shaft, remove the ring or loosen the allen bolt , adjust the fan blade assembly so it doesent bind, oil the motor with regular 10w40 motor oil and dust the fan, these are good little fans and that company has been making those since the40's, also sending user guide link.
http://www.vornado.com/manuals/allcirc.pdf
J
Aug 04, 2008 | Vornado Circulating Fan
Hampton Bay-Parisian II, 54" ceiling fan, model 670-760
I finally found the switch. It is on the motor. No dismantling is required. It is hard to see, feel around, it is where the blade holders start to curve.
May 09, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Casablanca Fan 3245T Ceiling Logo
522 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
