Question about Pentax ME Super 35mm SLR Camera
The quick winder not working
Hi there! When I try to wind the film to the next frame, instead of stopping there it carries on winding sometimes 2 or three times. I am missing a few frames because of that (many actually!!) sometimes works fine but very occasionally. I only just got my camera and i am desperate for it to work fine. Please help!!
  • 60 Answers
That camera has several rubber bumpers and gaskets in the mirror mechanism that have a tendency to turn into sticky gooey sludge causing the levers in the shutter and mirror mechanisms to get sluggish.
The latch that tells it to stop winding is not dropping into proper position when you wind the camera. Try holding the film advance lever all the way to the front when winding it to allow the latch to drop into place before letting the lever to return.
The only permanent solution is to completely disassemble the camera to clean out the old goop and replace them with newer neoprene fittings. My suggestion would be to find a replacement body since the repair is probably going to cost between $80 to $90 and you can probably find a good used body for less than that.
CameraRepairs
Posted on Aug 11, 2008
    Scholar:
  • 58 Answers
The rubber bunpers are best removed for a permanent fix. This should be included in a standard service.
To see how to open the camera up for repair and how to do this properly there is a camera repair site which deal with this and other cameras in detail. alternatively you can contact the author who can offer a very competitive camera repair service for these models.
Posted on Jan 21, 2009
  • Gordon Stalker
    Gordon Stalker Jan 21, 2009
    PS: You won't be able to get a good replacemnt body for less cost than a service. The replacement will have the same bits in it, and they will be in much the same condition. If you want a working camera buy one from a dealer who offers a guarantee, and can offer a service.
    You will find that whn you find one of these, the service will be cheaper. (For the obvious reason that the one sold with the guarantee has already been serviced. That is added to the price!)
Bobbin is not feeding properly- didn't wind on evenly.
It is important that the bobbin be wound smoothly for the machine to operate properly. First, check that you are threading the machine correctly to wind the bobbin. There is a tensioner for the bobbin winder that helps wind the bobbin smoothly so incorrect threading will cause issues. Also, try to wind your bobbin slower. There is no advantage to winding the bobbin on high speed.
If you continue to have bobbin winding issues, there is a standalone bobbin winder (SideWinder) avlb at JoAnn's or even Amazon for ~$30,. They are electric or battery operated. Be sure to verify your machine bobbins will work on the SideWinder before purchasing as some bobbins are not compatible. The bobbin winder is a handy gadget since multiple bobbins can be wound quickly, plus bobbins can be wound without having to unthread the machine, not to mention reducing the wear and tear on your sewing machine.
Nov 10, 2017 | Sewing Machines
Designer 2. Why isn't bobbin winder working?
For ~$25 you can buy a stand-alone bobbin winder from the local fabric store (JoAnns or Hancocks) or even online (Amazon.com).
Oct 24, 2015 | Husqvarna Sewing Machines
Myfriend has a Juki tl 98 Q on a frame. hooked up to the gracey sure stitch regulator. How do I wind a bobbin without having to unhook everything and put the foot foot petal on to wind a bobbin?
Simpliest solution is to buy a stand alone bobbin winder so you can wind them anytime. You can get one from http://www.sewingpartsonline.com/universal-automatic-bobbin-winder.aspx .
Otherwise you would need to wind enough bobbins before you start a project on the frame I guess.
Mar 13, 2011 | Juki TL-98Q
My bobbins sometimes don't wind right. The thread gets all tangled at the bottom of the bobbin instead of winding evenly. I'm sure it's user error because sometimes it works. Hoping you can help me figure...
when the thread is on the spool pin
1.guide the thread around the bobbin winder thread guide
2.insert the thread through the hole on the bobbin, threading from the inside to the outside
put the the bobbin spindle
3.push the bobbin winder spindle to the right (if you have a electronic machine the LED display
will show SP)
4.depress the foot control, when the bobbin is fully wound, stop it, & push the bobbin spindle to the left, cut the thread & remove it from the spindle
Nov 17, 2010 | Simplicity Sewing Machines
On loading a fresh film into the camera the motor winds through to the last frame ie does not stop at first frame
That's entirely correct. Your camera winds all of the film out upon loading and each shot then winds the film back into the canister. Your frame counter works in countdown mode telling you how many shots remain rather than how many you've taken.
Many other camera do the same thing. The beauty of it is twofold: if the camera back is accidentally opened, then the shots already taken are safely in the film canister (except for the last shot), also when the film has finished you wait less time for the short length remaining to be rewound rather than the entire roll.
Hope this helps, please take a moment to rate my free answer.
Sep 25, 2010 | Ricoh GR-1 35mm Point and Shoot Camera
My film in Canon ae 1 came out blank :S
I would say either the film didn't wind properly as it was going along,or the shutter isn't working properly.Did it make the whirring noise like it was winding after you took a picture?If you can,try taking a picture with the door open,no film,and see if the shutter moves.If it does open,it's probably the winder which pulls the film after a picture is taken.Good luck!
May 01, 2010 | Canon Photography
AE-1 When I advance the film the winder does not spin.
It is probably that the film in the canister is advancing and once it takes up all the slack in the film canister the film tightens and moves the spindle which then moves the winder.
Mar 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film winder is loose and meter is not accurate.
It is absolutely OK, my dad too has one (not older than urs). make it tighter, but u need some screws drivers (specially for cameras). Open the camera and tighten the screw holding the winder arm. Try this only if u have experience otherwise u may end up with a scramble of camera. About the F-Stop, i have no idea why this is so... might be the technology is gone too advanced compared to the 1978.
Aug 14, 2008 | Nikon FE 35mm SLR Camera
Film advance broken.
Press the rewind button and wind the film advance lever, It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Mar 27, 2008 | Pentax ME Super 35mm SLR Camera
67 type II winder problem
This is not a simple repair - if the wind lever is "ratcheting", parts will have to be replaced. If the wind lever is "free-wheeling", there might be no film in the camera, or the counter isn't working ( it has to be at #1 or above to cock the shutter ). It's a job for a repair shop.
Sep 20, 2006 | Pentax 67II Medium Format Camera
Pentax ME Super 35mm SLR Camera Logo
101 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
