Question about Dryers
Westinghouse space mates dryer heat was working was moved stopped working checked heater element resistance 11.8 ohms heater overload switch(?) was also conductive why else would heat not be working (what to check)? thanks
5 Suggested Answers
Oceti
  • 51 Answers
SOURCE: dryer spins but no heat
Did you check the power coard where it connects to the dryer? Start at the source. Make sure that you have at least 110v on each line. The dryer will tumble on 110v but requires 220v to heat. If you have 220v then check the t-stat and thermal cut-out on the blower. Check all wires for loose or burnt terminals. If all that is good it may be a bad motor or timer/control. I'm happy that you have a meter.
Good luck.
Posted on Dec 17, 2007
docjohn174
  • 943 Answers
SOURCE: Whirlpool dryer won't heat
hi. thanks for letting me answer.the only part that was not mentioned. is the timer contacs Y & R . the heat contacts in the heating circuit. thanks
Posted on Sep 29, 2008
MNTECH
  • 1543 Answers
SOURCE: Hi, I have a electric LG
Sure, looks like the high limit is your problem, but why did it fail? If your vent is good as you say, the dryer should cycle on the operating thermo (thermistor sensor in this case), and the high limit should never trip. I'd replace the 6323EL2001B thermistor too (back side of the blower housing), along with the 6931EL3003D and the 6931EL3001E which are mounted on the element assembly. Non heating issues can also be caused by a bad relay on the board or a bad centrifical switch in the motor.
Posted on Oct 05, 2008
Jahn27
  • 1554 Answers
SOURCE: No heat in a Profile
The thermistor at the back of the dryer is the inlet thermistor and it has a normal resistance of around 2270 ohm at room temperature, not zero. A zero resistance means the inlet thermistor is shorted and the control board sees it as an overheating condition and does not activate the heater relay. Replace the inlet thermistor with part number WE04X10111.
The thermistor on the blower housing is the outlet thermistor and it has a normal resistance of around 10000 ohm at room temperature. The heating is good at 17 ohms and inlet safety thermostat and the high-limit thermostat on the heater housing and the outlet safety thermostat on the blower housing must all have continuity.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 22, 2011
Stop heating and lights won't turn on
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but if the motor is not running, and the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Dec 10, 2016 | Dryers
I have a dryer dwsr ele 2406026 cv54 it does not the dry the clothes the heating element is working i was wondering if the dioid is not
overheating.
Read more :
Nov 21, 2016 | Dryers
I have a Miele dryer, model T565C.The system starts and stops, and now it will not start,and there is no power
overheating.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Dec 07, 2014 | Miele Dryers
Hoover HNV380 Tumble dryer, has developed a fault that causes the dryer to stop working after a few minutes use. When it stops working, the start light indicator flashes steadily, I have replaced the
overheating.
Nov 15, 2014 | Dryers
How to check the heating elements in GE harmony dryer
Oct 29, 2014 | Dryers
Dryer want heat already changed heating element would a bad thermistor keep it from heating
overheating.
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but you said that even the motor is not running, the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Sep 09, 2014 | Dryers
WHY WOULD MY DRYER START THEN STOP?
overheating.
Aug 27, 2014 | Dryers
Dryer not heating and cycle knob doesn't move
overheating.
Aug 16, 2014 | Whirlpool Dryers
I have a kenmore series 90 dryer 110.67902791 that i have replaced the High limit thermostat, the thermal fuse, the thermal cut off switch and the theromostat connected to the heater housing.... It will...
overheating.
Aug 16, 2014 | Dryers
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity -  - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Dryers Logo
Top Dryers Experts
