Question about Microsoft Xbox 360 Console
Run xbox 360 though a PC
I have a TV card in my PC (Dell XPS420 and want to run my XBox 360 though it. How do I set this up?
  • Anonymous Oct 26, 2008
    i have three red rings how do i fix this
به‌ سه‌ری تۆ نازانم هه‌ر باسی چی ئه‌که‌یت داماو به‌رنامه‌یه‌کم پێویسته‌ بۆ
xbox 3600 لێبدات له‌ کۆمپیوته‌ردا هه‌رکاتیک له‌م زمانه‌ تێگه‌یشتیت بۆم بنێره‌ به‌ زوترین کات
Posted on Sep 22, 2008
  • 43 Answers
You need the red yellow and white hookups on your pc
Posted on Sep 13, 2008
My xbox 360 wont play a xbox game even though it is on a compatible list. It is saying that the hard drive may be disconnected. It is playing 360 games fine. Any advise would be great
Have you got your 360 on live? The reason i ask is because if not it may be the case that you need to get an update from xbox live before you can play the game even though its on the compatible list. Also it might be that you need an xbox memory card (Not a 360 one though)
Hope this helps
Jan 08, 2011 | Video Game Consoles & Games
My dell xps 420 will not power on. power light
Hi
If your system's power light blinks amber, it means the computer is receiving electrical power, but an internal power problem might exist.
Do the following to tackle this issue:
  • If applicable, make sure that the voltage selection switch which is at the rear of your system matches AC power in your area.
  • Ensure that the power cable is securely connected to system board.
Here are links with pictures to assist you in opening the system and reconnecting the internal cables.
Please follow safety instructions before you perform these tasks. Here is a link, which gives you complete safety instruction.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372453
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372490
Next is to see the system board design. Here is the link.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1402834
and if you wish to research a bit more here is the link,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1076480
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1097292
Here you will find complete manuals for further research
If this does not resolve the issue, then the motherboard or processor is faulty and you need to get it replaced, so if your system is within warranty why pay extra, get it replaced from Dell. Else contact a local tech and he'll help you out.
Please rate as per the assistance level. Thanks :)
May 21, 2010 | Dell XPS 420 PC Desktop
My tv runs on pal50 but some games on xbox360 run on pal60 , how do i play these games on my tv
Standard definition TVs loadTOCNode(2, 'moreinformation'); If you connect your Xbox 360 console to a standard definition TV, follow these steps to set the Xbox 360 display settings to PAL 60 Hz:
  1. Turn on the Xbox 360 console.
  2. In the Xbox Dashboard, select System, and then press the A button.
  3. Select Console Settings, and then press the A button.
  4. Select Display, and then press the A button.
  5. Select PAL settings, and then press the A button.
  6. Select PAL-60, and then press the A button.
  7. When you are prompted to keep these new settings, confirm the settings, and then press the A button.
Note Some older TVs do not support PAL 60 Hz. If you do not know whether your TV supports PAL 60 Hz, contact the manufacturer of your TV or see the owner's manual.
Mar 07, 2010 | Microsoft Xbox 360 Arcade
I have an Xbox 360, and when I got an HD tv, I got the HD cords for it and when i use the switch on the cords to go from standard tv to HD, my screen goes black and i get diagonal lines that run up the...
Either the cable you are using is no good, or there is an issue with the internal video subsystem. Try changing cables, and if possible, try a different input on your display. If the issue still exists then you may have an internal issue. The only way to diagnose this is to have your local Xbox repair center diagnose it unless you have the tools and experience to do it yourself. Certain parts of the subsystem can be replaced, but for the most part the entire system is replaced.
Mar 04, 2010 | Microsoft Xbox 360™ Premium White Console
NO SOUND ON XBOX ELITE
I would suggest that you turn your CAPS LOCK off, and re-post so people can actually READ what you tried to post!
Apr 20, 2017 | Microsoft Xbox 360 Elite Console
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 Video Problem
Have you adjusted your tv settings at all, rather has anyone screwed aroung with your tv?
Sep 21, 2008 | Microsoft Xbox 360 Console
My Xbox 360 won't play Xbox 360 games
run through your initial set up again.
Aug 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
190 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
