Question about Creative Labs WebCam Live!
Problem connecting video P.C. to mac 10.4.11 video p.c.
Unable to connect
  • picaprince Jul 05, 2008
    unable to connect a video link from a Mac power p.c running 10.4.9 to a P.C. running windows and vice versa
    not able to connect a power Mac running 10.4.9 and a P.C. running windows
Unable to Find Movie When Connected to Computer
Your MAC can't show you every known video format. Look what format is on the camera and when you put the correct software on the MAC (that came with the camera on CD or DVD) you will be able to import and transfer the video's to the format your MAC can show.
Nov 28, 2013 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
I am unable to import video from my Panasonic DVC62. when i connect it with my mac computer it doesnot show any icon in desktop. can u help me to solve this problem please.
Use a firewire cable to connect the camera to the Mac. Nor a USB cable.You will not see an icon on the Mac desktop.If iMovie does not open automatically then open iMovie.
Jan 07, 2012 | Panasonic AG-DVC62 Mini DV Digital...
Unable to connect to the access point
Hi tissa,
I see you are unable to connect to your Access Point as noted on the question provided.
First console cannot connect to an Access point if it is Password protected.
You will need to disable the Password or Network Access key from your Router to be able to get your DSi to connect to your Access Point freely.
To get security with your Nintendo DSi connecting to your Access Point in your Router setting you can enable the MAC Address filtering and get your devices MAC addresses and have it registered or input in your Routers MAC Address Filtering to be able to get your DSi connected wireless and at the same time have your Laptops and other wireless devices connected.
for the MAC address you can call you Internet Service provider on the issue to give you detailed info on how to access you Router settings for the said connection.
I hope that this will help.
Thank you fo choosing Fixya,
mvincentc
Jul 15, 2011 | Nintendo DSi White Console
I appear unable to obtain a dcr-hc24 handycam driver for my IMAC?
Not needed.
Connect your camera to the Mac with a four to six pin firewire cable and you will be able to capture.
Note: Some newew Macs have 800 firewire ports which use a nine pin cable.
Mar 15, 2011 | Sony Handycam DCR-HC24E Mini DV Digital...
MAC Book Pro unable to connect the wi-fi. Connection timed out er
Reset your wireless password/key. Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Mar 12, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Cannot connect to internet/unable to ping server
Try to reboot both your mac and your modem, and reconnect all cables.
May 29, 2009 | Apple iBook Mac Notebook
Mac notebook unable to connect to the internet wirelessly
go to network setting then assist me , select default location after completing it . go to advance setting then check dns server and add the server ip adress in it save the settings check it is working. rate if helpfull
Apr 15, 2009 | Apple aluminum 13-inch MacBook laptop-...
JVC videocamera isn't seen in Finder on MAC using Firewire.
Hi, Sorry you are having problems,
You are really really close, be sure the camera is plugged in and turned on on preview mode and then launch ( Open ) the iMovie application on your Mac, the iMovie application will recognize the camera and probably prompt you right away if you want to import video from the camera.
There you go, it's that easy...
Mar 26, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Unable to download video from JV dvl520 to my mac
Is it connected with a firewire cable? Have you been able to import the video before to your Mac?
If it it says it is in USB Mode - then change the camera menu setting to DV.
Power off the camera, shut down iMovie - power on the camera then launch iMovie check again. (Assuming your using iMovie).
Dec 20, 2008 | JVC Cybercam GR-DVL520 Mini DV Digital...
Sony DCR-TRV530 firewire connection not recogized on Mac; won't import or capture video
try to use USB wire and then install the driver to your pc. hope that helps you!
CHARCOIS
Aug 21, 2008 | Sony Handycam DCR-TRV530 Digital Camcorder
Creative Labs WebCam Live! Logo
12 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
