Water too hot on most cycles. - Washing Machines
  • 225 Answers
First thing I would check is that the cold water supply is running OK - especially no blockages in inlet filter, no kinks in pipe etc.
Hope this helps ya a bit . D
Posted on Jul 05, 2008
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Getting only cold water to my washer; hot water is not there
Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
Mar 29, 2009 | Kenmore 20722
Hot water goes into cold water washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG WM-1832C Front Load Washer
Water temperature
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Aug 26, 2008 | Maytag Washing Machines
GWL15 no hot water on Regular or Heavy Duty Cycles
should you select a 40* wash it would not be right if the machine filled with hot water, as the water in the house tank is a lot more than 40* ( around 65* i think?) this would just damage the clothes and i am sure you would just complain again at that.
if the machine works fine then there is no problem
Oct 10, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
