My os is windows 2003 server
my computer is IBM server X3400
When booting, the following message appear:
controller monitor failled, controller not started.
Please, helpe me
You can install Windows 2003 using IBM Service Guide CD. Its an image file (.iso) . Burn it after download . Then boot from cd and follow the simple wizard . Find the link below
try other good known hard disk install it on your server, if it detect the presence of that disk then your hard disk previously installed has the problem, it going to be defective sooner or already defective
Welcome to Fixya
The problem is with the raid controller . Either the controller is faulty or it is due to dust or happen some shake. To rectify this issue do the following
1: Switch off the server
2: Remove the Raid controller from the server and clean the dust . ( Please Don't touch with hand just blow air )
3: Clean the Controller slot
4: Refix the Controller and power on the server .
5: Check whether the controller is booting or not .
6: If you gets same problem then replace the controller
In order to install Windows 2003 , you need Ibm Server Gide cd . Boot from the cd and follow the wizard
You can download the software from below link
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5087263
Its a image file . So after download burn image to cd and boot from cd.
That' all
The install is fairly easy. Before you begin make sure if you have SCSI adaptors installed have the drivers for them on hand. If you do not have these drivers you should download them to a 1.4MB floppy disk. When you are ready, put the Windows Server disk in the cd/dvd and reboot the IBM. Follow the instructions on screen and you shoud be fine. From start to finish it should take you about 1 1/2 hours to complete everything.
