Question about Refrigerators
Proline pc178a fridge freezer still has light in fridge compartment but has stopped working and freezer has defrosted. Electricity not the issue
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided.
http://www.repairclinic.com/0088_4_1.asp#Level1_1
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Unfortunately, we can't describe all of the possible problems and repair solutions here. If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
Fridge and freezer stopped working but fridge light still on should the orange switch by the light be on or off don't know if that is the defrost button
Sounds like a motherboard or defrost control board. Can you tell me the model number found inside the fresh food compartment or around fresh food section door frame, Without the model number it is hard to guess what the switch is that you are asking about, Thanks Sea Breeze
Dec 08, 2012 | Refrigerators
My proline fridge freezer not cooling
I have the same problem with a proline plc 190w fridge freezer not cooling in the fridge compartment please help it's my mums and she can't afford a new one , thanks in advance
May 19, 2012 | Refrigerators
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
LARGE AMOUNTS OF ICE FORMED IN THE MAIN COMPARTMENT
Well, short term, you'll have to unoad it and defrost manually.
Sounds like the auto-defrosting system has a problem. A likely cause is the defrost timer.
May 04, 2009 | Refrigerators
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Fridge stopped working
if freezer section is still cold yuo have either abad evaporator fan or a defrost issue, is the back of the freezer compartment frosty? if so look for defrost problem, (open defrost thermostat, open heater, or bad defrost timer.
Feb 04, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Fridge is warm, freezer is cold!
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves no working. Good job trouble shooting!
Jan 13, 2007 | Zanussi ZX55 / 4 Bottom Freezer...
Refrigerators Logo
673 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
