Question about Cameras
My alpha 700 the battery was at 32% then the drive stoped working properly the lens would turn a fraction, when the batterys fully charged it seems to work ok the camera is onley three months old
    Master:
  • 726 Answers
Well if it stops working at 32 % ,were the power of a low percentage is not reaching the full capacity for the camera
seems like the battery its self is dying at a low percentage like the cells are dying if you get a new battery this will be 100% back to normal
happened the same to mine but when mine got to 15%
Posted on Jul 05, 2008
    Genius:
  • 1,847 Answers
Seem the motor is not giving proper output, is the unit is in warrenty the best idea is to return or replace it .
  • Legin Varghese
    Legin Varghese Jul 05, 2008
    a three month old camera should not behave like this, the motor is not working efficiently so the better option is to replace it.
Model PL81. Why does it zoom, beep, and shut down?
Are you positive that the battery is good? Turning on for a few seconds and then shutting down is a classic symptom of a battery that did not take a proper charge and as soon as the surface charge is used, unit will shut down. And what if your charger is not properly charging the battery?
If you have a battery eliminator try that in lieu of the battery to see what happens.
Mar 28, 2016 | Samsung Cameras
Problems with linhai 80cc quad
Battery or battery cable connections. After you get it running make sure the charging system is working. Maybe riding it ran the battery dead from it not charging properly.
Feb 11, 2012 | Linhai People 250 Motorcycles
Turn on camera lens comes out then goes back in and turns off
Have your camera battery been charged fully? It seems problem about battery or the lens If your battery are AA batteries please note the battery type of the battery if your camera support else If the battery is OK, there maybe something wrong with the lens
Sep 24, 2011 | Cameras
My Honeywell Ademco 6160 Alpha Keypad Vista 10E low battery light keeps flashing even after I've change out????
The low battery light will stop flashing when the new battery you just installed become fully charged. It will take some time for the new battery to become fully charged.
Jun 06, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
Camera stoped working and lens is in the out position, i can't get it on again
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
or
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera.
2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
Feb 28, 2010 | Samsung Digimax S750 Digital Camera
My dvd just stoped playing movies and cdvds
Power down, remove battery, remove the drive. Power up and boot fully, then shutdown. Reinstall the drive, then power up and see if it read the DVD. Also clean the lens. If still don't work, replaced the drive.
Nov 16, 2009 | Gateway MX6956 Notebook
Battery had bad cell, replaced battery with new 700 cold cranking amps, starter seems locked want or cant turn engine over,bad starter or what? 88000 original miles!
Check the battery cables for corrosion that may have eaten through the wire. Measure the voltage at the battery posts--should read 12.6 volts--if not, charge the battery overnight with a low rate (4-8 amps) charger. If the battery won't charge, take it back for another unit. If the starter was working before, it should still work if it is getting proper voltage.
Oct 08, 2009 | 1997 Pontiac Bonneville
My cybershott70 won't turn on
Dear Sir,
The problem could be with your camera to battery connections. The
The secret to making digital cameras work better is having good electrical contacts between the batteries and the camera.
Digital cameras require lots of power. If electrical contacts are not really good, this can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD display is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. With bad contacts, cameras do strange things like making bad pictures or shutting off with the lens out. For cleaning procedure you may visit this link http://www.google.com/base/a/4210404/D13701973093918363271
Aug 27, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Computer stoped working
If you're certain that the battery is fully charged, then there could be an issue with your hard drive, or possibly motherboard.
Has the laptop ever been wet, or outdoors overnight?
See if you can boot from your disk drive by inserting your operating system disk in the drive when you turn it on.
Also double check that the outlet you're using is actually supplying power, I have bad outlets in some parts of my house where my laptop won't charge up.
Hope that helps, keep me posted
Dec 11, 2008 | Acer Aspire 3680 Laptop
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
