Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2008 softail deluxe feels like its dragging rear tire doesnt feel right like its hesitating /new pipes recently
Bike needs tuning wasnt done when new pipes put on since it was done back in august when initial pipes were replaced . I changed pipes due to location of pipes vs skin!!!!
Posted on Jul 06, 2008
2017 Softail Deluxe turn signal LED kit not working
Hi, Traceyandchriscolvin you need a load equalizer for more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Install LED Brake Lights Turn Signals on Harley Davidson Complete Guide...
Harley Davidson Softail Workshop Service Repair Manual 2016 $10
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
2016 Harley Davidson Softail Deluxe Owner Manual
Instant Tech Relief To speak to me personally absolutely "FREE"
Jun 12, 2017 | Harley Davidson FXST Softail Standard...
Rear end feels really loose when turning from stop
Check the tire inflation. Also, if you can jack the tire up off the ground, rotate the tire and feel across the top of the tread. If there seems to be any high/low spots or feeling of side-to-side tread movement, you may have a separated belt in the tire. This can cause the "loose" feeling you are getting.
Jan 13, 2015 | 2008 Nissan Frontier
2008 softail deluxe speedometer doesnt work
Hi, Anonymous the vast majority of speedometer issues is caused by the speed sensor and or the wiring, a faulty speedometer sensor and or connection will automatically interrupt proper turn signal and flasher operation. On Sportsters the sensor is located on top of the engine case behind the rear cylinder, on big twins, it's located on the right side of the transmission case between the starter end cap and the transmission top cover. Remove the bolt/screw that secures the sensor and lift the sensor out of the case. Inspect it for damage and contamination, if there appears to be no damage wipe the end of the sensor clean and reinstall, you can go for a short quick test ride to see if the speedo is working. If the issue still exists grab your test light and unplug the harness connector from the sensor, check for power (red wire) and ground (black wire) continuity coming from the speedo, there is also the connector that plugs into the speedometer, also, look for corroded, broken or loose pin/sockets. If everything checks out OK then replace the speed sensor. For more information about your question and valuable "FREE" downloads that you will need please click on the links below and for specific information or answers please feel free to contact me at xlch@mail.com. Good luck and have a nice day
Harley Diagnostic Codes 04 Present DG Custom Cycle
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Feb 26, 2014 | 2008 Harley Davidson FLSTN Softail Deluxe
Rear tire hard to access valve stem
Hi Lou, sure do get a cycle jack. For around $100 includes shipping you can get a nice one. Please to visit website below:
Black Widow Motorcycle Jack Lift
Good luck
Feb 23, 2014 | 2008 Harley Davidson FLSTN Softail Deluxe
Vibrates in 6th gear the minute I hit 70 mph
Hi Jackie, and the usual suspects are:
1. Wheels and or tires unbalanced, worn or damaged.
2. Engine/transmission/vehicle not aligned properly.
3. Primary chain badly worn or links tight as a result of insufficient lubrication or misalignment.
4. Engine to transmission mounting bolts loose.
5. Upper engine mounting bracket loose.
6. Ignition timing incorrect/poorly tuned engine
7. Internal engine problem/ flywheel shift
8. Broken frame
Good luck
Jun 12, 2013 | 2008 Harley Davidson FLSTN Softail Deluxe
Rear brake is dragging on 2008 harley davidson softail deluxe
Hi Anonymous, your brake pads may be worn out, for more information about your question please visit the websites below. Good luck and have nice day.
How to Change Rear Brake Pads on Harley Street Glide
May 25, 2012 | Harley Davidson Motorcycles
I need to see a video of oil being changed on a 2005 softail deluxe
I doubt you're going to find a video of the oil being changed on a Softail. To change the oil on your Softail, look at the oil tank from the right side of the bike. At the lowest point on the backside of the tank, you'll see a large hose coming from the tank and running down behind the transmission. The hose comes back out from behind everything at the lower part of the frame behind the exhaust pipe and looks like it connects to a crossmember of the frame at the bottom. Feel underneath the crossmember directly underneath the hose and you'll feel a drain plug. Remove the plug and the oil drains out of the tank.
Good Luck
Steve
May 06, 2011 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
What is the correct air pressure for a 2005 softail deluxe
Correct tire pressure - 30 PSI in the front
36 PSI rear single rider
40 PSI rear two up riding
Always refer to the side wall of the tire for air pressure. You may not be running Dunlop tires.
Aug 28, 2010 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
Truck has been sitting for a couple years in
HI THERE
YOU PROBLEM IS YOU NEED TO REPLACE THE PARKING BRAKE CABLES .THEY ARE RELEASED BUT NOT ALL THE WAY CAUSING THE SHOES TO SIT TO CLOSE TO THE DRUMS.WHEN ADJUSTING YOUR BRAKES HAVE THE REAR END OF THE TRUCK OFF THE GROUND TIRES ON AND SLOWLY ADJUST ADJUSTERS AT THE SAME TIME TURNING THE TIRE UNTIL YOU FEEL A SLIGHT DRAG REPEAT FOR OTHER WHEEL
Jun 10, 2009 | 1994 Ford Ranger Supercab
Lands Phones Logo
101 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
