Question about Toshiba Televison & Video
Toshiba 52HM94. No picture on digital channels.Sound ok. Analog channels ok dvd inputs ok.. Ran on board diagnostics ok. Have service/parts manual. Any ideas? Thanks, Gene
  • esim-325 Jul 05, 2008
    Of course it has a digital tuner. It worked fine for the last 2 years.
  • djspencer Jan 18, 2009
    i have the same problem on my 62HM95. did any body find a solution?
  • 1,847 Answers
Are you sure the tuner inside the tv is a digita one?
Posted on Jul 05, 2008
Toshiba TheaterWide 52HM94 HDIM Input
The 52HM94 is a somewhat older set--best guess is it is not compatable for this use.
Aug 29, 2012 | Toshiba TheaterWide 52HM94 52" Rear...
Digital surround mode doesn't work,just analog dvd 6ch.input
Failure of the sound processor. All you can do is to remove the cover, clean the insides, check the cables to make sure they are still firmly plugged in and then measure the 5 volts power line from the source. If all appears OK the the processor has died - a replacement board is mandatory. It will be cheaper to buy a new receiver .
Sep 29, 2011 | Technics SA-DX850 Receiver
When i choose digital surround mode, there is no icons of surround loudspeakers, and there is no digital 5.1 surround sound. i have to press button DVD 6 CH INPUT. it is analog connection. sometimes when...
First of all, you don't identifiy the hardware.
Second, DVD 6 CH INPUT is analog so how would the device KNOW if all 6 channels are present? ONLY a device with the required 6 analog channels should be connected there. That input typically bypasses ALL internal digital processing.
Elaborate more on the digital source(s) that are failing and assure us you have looked at/exhausted what the manual says for setting them up.
Sep 08, 2011 | Audio Players & Recorders
I bought a TOSHIBA 32KV500B tv. At the Initial Installation mistakenly I selected "yes" for 'do you want to search analogue channels?' guestion. And then I lost all my automatically selected...
I had this problem and searched the internet for hours looking for an answer and was given the initial same reply as this and it does not work. To solve this problem all you simply need to do is press source button on the controller followed by pressing the DTV/USB option. All your digital channels will come back to you and you will find the menu setup options you are looking for!!!
Feb 12, 2011 | Toshiba Televison & Video
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
Philips 32pw9617 crt no picture on analog channels but sound ok
this is your tuner board faulty replace tuner board hope this helps
Mar 26, 2010 | Televison & Video
The t.v. does not have a picture or no sound but the dvd works?
U have the original remote?Tries pressing any of these buttons.Said Input,Function or AV buttons.U will get Tv,Video 1,2 or Input 1,2.Continueously pressing the button to go out to the display said TV lable will get tv signal.U have cable right?No,cable or satalite these day will not get a tv signal for an Analog tvs.It all digital,have analog tv to recieve free air tv must have a Digital Converter box for analog tv.
Mar 24, 2010 | Televison & Video
No sound on analog channels
I came across this problem yesterday. Digital channels sound... Analog no sound. press the tv button on your remote to change it from DTV/TV
go to any channel you want. press the menu button then go along to Sound setup. In there you will see quite a bit. I went down to an option in there.. it was sound input or something similar. this was set to BG I changed this to 'I' and the sound came straight back on. Hope this helps you out.
Little Dish Fitter
Sep 02, 2009 | LG DR787T DVD Recorder
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at ,
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Televison & Video Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
