Question about Creative Labs ZEN Vision:M Digital Media Player
Davy Hey my zen vision m started freezing and it went to the recovery mode i formatted it cleaned it up then tried to reload firmware it erased the old firmware but did not put the new one in when i turn it on it says firmware problem and goes to recovery mode So i went to www.creative.com and got the firmware upgrade but now my vision m said it is docked but my computer just cant detect it so now it wont let me put the new firmware on it plz help i am goin crazy
What verson of Windows Media player have you got on your pc?
Find one with version 9 install the creative software and then try the reload of the firmware .Zen has problems with windows medai player 10 - 11.
Posted on Jul 08, 2008
I have a creative zen m vision which is not working if I try to reload firmware I get a message harddidk problem - how do I proceed
1 HD damage could be done when you drop the Zen and you hear noises inside, some times the display just shows the Creative logo and no more.
2 the display just show the Creative logo, no noises inside, you can tray to put in Recovery mode as mentioned in the other solution and then erase firmware then reload firmware, this firmware can be downloaded form creative page,http://us.creative.com/support/downloads/download.asp?MainCategory=213&nRegionFK=&nCountryFK=&nLanguageFK=&sOSName=Windows+XP&region=1&P
However
Before you go to all that trouble though try these steps:
1. Connect the device to the wall charger.
2. Hold the power switch to ON.
3. Put a paper clip into the reset hole.
4. Continue holding the power switch on until the Creative logo appears.
5. Select Format All from the Recovery Mode menu. (Note: THIS WILL ERASE ALL DATA FROM YOUR DEVICE! - but it's better than buying a new device)
6. When the reformatting is done, select Reboot from the Recovery Mode menu.
Jan 08, 2011 | Creative Labs ZEN Vision:M Digital Media...
Creative zen m vision won't start up,
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
If the battery is too low, charge the battery fully before continuing
2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
* Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
* Format All (Formats the players hard disk - Note: all contents will be lost)
* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
http://dmzweb4.europe.creative.com/...com:80,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Nov 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
Stuck in recovery mode--would love to avoid buying a new mp3
I had the same problem as your and it stopped working yesterday. After search for helps and now it is working again after I reloaded the firmware. But unfortunately everything is gone. You have to reload your musics again. You can try this out: 1) go to creative labs website to download the "Recovery Tool". 2) at Recovery Mode of your zen there are options: Clean Up, Format All, Reload Firmware, and Reboot. Try out Clean Up first if it still not working then try to Format All. After that try the Reload Firmware. After you done the Reload Firmware. 3) Shut down your Zen and try to connect it to your computer. Now your Zen will automaticlly power On and computer will recognize it as a drive. 4) Open the Recovery Tool you have downloaded at creative labs website. This tool will detect your Zen and follow it's instructions: It works with my windows Vista. Well, it works for me, I think it will work for your too. Good Luck!
May God bless.
Jul 15, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen vision m firmware problem
Greetings,
Lotsa people are having the same problem with the firmware updates. Go check for your warranty, the product was working fine before applying THEIR firmware update.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 28, 2008 | Creative Labs Zen Vision Digital Media...
Recovery Mode
I agree, use the Reload Firmware tool on recovery mode and then upgrade the firmware from the website. If you get "firmware failed!", then try it from a different computer.
May 08, 2008 | Creative Labs Zen Digital Media Player
Firmware Problem + Can't upload new Firmware
http://www.anythingbutipod.com/forum/showthread.php?t=10960
go here
Feb 20, 2008 | Creative Labs ZEN Vision:M Digital Media...
Dear All this problem is caused if the computer has windows media player 11 installed. I googled this for days trying to fix it - & was relieved when i finally sorted it - it's very easy. Just do the following.
Use a computer that has XP (either pro or home edition) (forget about vista....). go to add/remove programs - uninstall windows medi player - on my PC it does a roll back to WMP version 9. There's also a program called "Windows media format runtime 11" which comes with WMP11 & you need to uninstall this too - otherwise it still won't recognise the player.
Then restart your PC. Then make sure you have downloaded the lastest firmware version - just google it - trying to find the right one on the creative website is not easy - their website is poor - there are quite a few other places you can download it from.
Then I clicked the "reload firmware" option in the recovery mode (I had already deleted it 4 days ago). Then when your PC has restarted plug in your Zen, it should come up something like "MTP device recognised". Now when you double click on the firmware downloaded to install - it it will recognise the player & you can click the upgrade button. It does the upgrade & puts the firmware back on the ZEN. I got a message saying "firmware upgrade failed" at the end although when I started the player - it booted up as normal & I was able to reload & play my music.
This sure beats the "send it back to John Lewis, pay 60 quid & wait 6 weeks for it to come back " option - if like mine it's out of warranty
Feb 17, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision M
If you reset it and it goes back to just the zen screen, then I had this problem once too. You need to go to recovery mode (which is still possible).
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
It will display the following options.
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.Here's the link to the site where I got the info from. (it's another forum). Good luck!
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=151527#M151527
Jan 26, 2008 | Creative Labs ZEN Vision:M Digital Media...
My zen is freezeing
1. I'd try a system clean up first (instructions below)
2. definitely upgrade your firmware (http://us.creative.com/support/downloads/)
3. If all else fails, back up all your music on your PC and format it (instructions below)
.... from Creative's site
Reset, Format or Clean Up a Zen Vision:M If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off. If the battery is too low, charge the battery fully before continuing
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. vision_m_reset1.jpg
    • Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
    • Format All (Formats the players hard disk - Note: all contents will be lost)
    • Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
    • Reboot (Reboots the device).
Jan 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
Clean Up Scans the player and removes invalid links from its music library.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN Vision:M Digital Media Player Logo
140 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
