Paper keeps getting stuck in printer whem im trying to print
  • lynette45 Dec 12, 2008
    My paper too is getting stuck in the printer. It feeds half way and then I get a message that the printer is out of paper. I opened the front feeder, cannot find any paper jams. The paper is easily retrieved once I get an end. In the several times I tried to print, sometimes the paper gets fed in at an angle which makes it seems as if something is blocking it on the right, but no paper jam can be seen nor am I getting a paper jam message. I would really like to know how to open the printer in ways other than the access door at the front.
Threw the brother printer out the window and bought a new one!
Posted on Sep 10, 2008
My paper keep getting jam and will not go into print
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
May 14, 2011 | Office Equipment & Supplies
Loaded paper not going through
Annie, did you try to feed it one paper at a time? in many printers the feeder doesn't do a good job separating one paper from the rest.
another thing you can do is to turn off the printer and back on. this might get it out of the stuck status it is in.
did you check there isn't any paper stuck in the feeder?
Mar 10, 2010 | Lexmark X5470 All-In-One InkJet Printer
Message says Paper Jam, but there is no paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 25, 2009 | Brother MFC 420CN All-In-One InkJet...
I keep getting paper jam messages when there is no paper jam.
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 23, 2009 | HP Photosmart C4180 All-In-One InkJet...
see if the paper sensor are jam or if the machine have paper jam.
Jun 18, 2009 | Canon Office Equipment & Supplies
Paper is stuck and i can't get to it
Hope that helps!
PREM
May 19, 2009 | Dell 924 All-in-One InkJet Printer
Can't get the hp4650dn to print from tray 2 keeps defaulting to 1
Hi Im Ray.
1st check to see if the paper sensor in tray 2 has not got stuck.Take the paper tray out of tray 2 and look in and up right hand side there should be three levers that move up and down.
2nd have a look at the onboard menu and see if the default tray is set to tray 1.
Check onboard paper settings.
Mar 20, 2009 | HP LaserJet 4650dn Printer
Printer is not working
Try pushing the print head carriage with a bit of gentle force. It is getting stuck, and hence the error. You may have to open side and top covers to reach this. Note: this is not the cartridges, but another device that moves back and forth on the slider carriage.
May 15, 2008 | Canon Office Equipment & Supplies
R265 chewing paper
Suggest a small piece of paper or dirt is stuck in the print path near the print heads. Use vacuum tube to **** out any dirt
Mar 19, 2008 | Epson Stylus R265 InkJet Photo Printer
76 people viewed this question
jasbo
jasbo
