Question about Sony PlayStation 2 (PS2) Console
Fuzzy and flickering picture
When i go to play a copy of shadow hearts: from the new world, the picture goes fuzzy and flickers, making it impossible to play. the disk was second hand but appears scratch free and the leads are all properly connected. The problem is only triggered with this game, however even when i take out the disk and try a different game, the picture remains just as bad, even in the ps2 browser screen. but it worked fine before i put in shadow hearts. please help
  • ali_h04 Jul 05, 2008
    its happened on more than one tv but never as bad as now, im just reluctant to think its the av cord as the problem never occurred until i put in that particular game. thank you for your help though, i'll keep trying
    Problem Solver:
  • 16 Answers
Try bending the connectores slightly up and down and check if the problem will be fixed, if that seems to solve the problem purchase anothe AV cord for your PS2 also try testing your PS2 on another tv and then let's see if it will solve the problem
Posted on Jul 05, 2008
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Samsung television flickers to bright white fuzzy picture
In such cases, we have to ensure that it is not the input device that is causing this problem. So, please switch your input device to something you are sure, works. If you notice same problem, look for loose contacts in inter connecting cables and jacks. If problem persists, please refer it to a qualified service technician.
Jul 28, 2012 | Televison & Video
I am having ongoing problems with Samsung R519 laptop screen as it goes all fuzzy then goes normal then goes fuzzy again I have replaced the screen and screen cable and it still goes fuzzy then goes normal...
Have you updated the video driver in the laptop, there have been cases where the screen gives a variety of symptoms because the driver was outdated, if that fails! as crazy as this sounds do a fresh install of your operational system. I serviced a laptop with a flickering screen, I reloaded windows and got rid of the problem.
Apr 16, 2012 | Samsung R519-53S Notebook
What's your problem?On going problems with Samsung R519 laptop after all the advise I tested laptop on separate monitor and it worked fine with no problems I bought new screen lead and still had p
The external monitor has proven there is no problem with the video graphics card, I'am concerned that customers have complained about faulty screens.
I have changed a lot of displays without issue, there is a major circuit board mounted behind the screen that plays a roll in picture production so if something goes wrong you get all kinds of symptoms from fuzzy images to multi color lines to a blank screen. I would suggest getting your money back because of his track record, also go online to Samsung and contact customer support and the technical department to see if something was over looked. Question! is this a new or used LCD display?
Apr 06, 2012 | Samsung R519-53S Notebook
Picture problem
Sounds like its in pal mode. With no dvd in it, go to menu and see if thats the case. Switch to another setting to see if that helps
Mar 13, 2012 | Durabrand Televison & Video
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
PIcture Flickering
you may have a convergence problem. need to replace the stk 392-040 2 eq..
Jul 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Rear Projection... Hitachi tv
humm.. could be a crt or a high voltage problem..flyback transformer or high voltage splitter... have a tech check it out for you.
Nov 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture fuzzy and flickers (like tracking)
The flicker could be caused by a bad solder connection arcing or even a bad picture tube. If you notice the screen getting drawed in from the sides as well as top and bottom it may be in the power supply regulation circuits, but the focustat around the area of the high voltage transformer could also be breaking down. If it's over about 8 years old, I would replace it with a HDTV set. Check out the latest issue of Consumer reports for ideas. (No I don't work for them-I've just seen so many people just walk into a *Mart and pick out a TV like they were choosing a box of cerial without doing a bit of research to find one that would suit them best, that I'm trying to put out a word to the wise among us).
Feb 04, 2007 | RCA F35673MB 35" TV
Sony PlayStation 2 (PS2) Console Logo
199 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
