Question about IBM IntelliStation Z Pro 6221 PC Desktop
DISK BOOT FAILURE
I have the message "DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER". All I did was take out and put back in one 216 MB of RAM. What do I need to do?
Thank you,
Joey
    Problem Solver:
  • 15 Answers
If you reinstalled the memory correctly it should fire right back up. But try this, when press the power button, hit delete and go to set up, under PC management find the Boot Order String, select the Floppy as the first device if you have one, the Hard drive as the second Device and the CD/DVD as the last device. Should go straight to the hard drive as the primary boot device. Hope this helps.
Posted on Jul 05, 2008
Boot disk failure. Insert system disk and hit enter
Remove the CD player, open it and try cleaning the lens then put it back and try again if it doesn't ,convert the cd image to Flash disk using Rufus a free tool from the internet, then install your o.s using Flash disk.
Jul 17, 2016 | Microsoft Windows 2000 for PC
Getting message "Disk Boot Failure Insert system disk and press enter" using window xp platform and have MCA fee antivirus software
this happens either the boot sequence have changed or your hard drive is not recognised by the BIOS
Jan 26, 2013 | Computers & Internet
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
HI THERE, I AM TRYING TO INSTALL A FRESH COPY OF WINDOWS ONTO A ANOTHER COMPUTER, I AM USING THE CD'S I ALWAYS USE SO THEY ARE BOOTABLE DISKS, I KEEP GETTING MESSAGE BACK "DISK BOOT FAILURE, INSERT SYSTEM...
First you need to make sure that the CD drive is selected as the first boot device.
You can set that by going into BIOS setup by pressing Del/F2 during system startup OR during startup press F12 and select CD drive from the boot device selection menu.
Press Enter.
See if the system is able to start from the disc.
Thanks
Feb 20, 2010 | Computers & Internet
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Disk Boot Failure
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Aug 08, 2009 | Computers & Internet
Disk boot failure prompt
hi, SInce u do not have a HDD u will need to boot up from cdrom, for that in the BIOS 2nd options,change the boot up sequence first to cdrom , second to any other disk.. let me know
Dec 17, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Consustently get "DISK BOOT FAILURE _ INSERT SYSTEM DISK AND PRESS ENTER" message
use xp sp2 bbootable disk and simply run a repair installation it should heal your system
Oct 17, 2007 | Mach Speed (MSNV-939) Motherboard
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
IBM IntelliStation Z Pro 6221 PC Desktop Logo
354 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
