Question about EliteGroup Computers & Internet
Geforce7050m-m motherboard Fresh install from box do not get a signal to monitor and cd drive when it opens closes immeditly afterwards or part way through opening...3gigs mem on the board new sata drive 500gig hooked to it and new 500w power supply using one PCI slot for a mx4000 graphics card...Any idea on how I can get anything to appear so I can load a OS to it????
  • 1 more comment
  • darastrix00 Jul 05, 2008
    ok took graphics card out changed to one stick mem still did not work on that attemp
    ok switched to second mem stick got bios to pop up but it changed dram speed am guessing on boot with no os board is not reading or will not read a full 3 gigs on it since both these sticks work in my other computer..tried with the 2 gig first did not work but worked with the 1 gig stick and bios changed the dram speed to 533 for first part of boot..
    Yup am working on installing the OS now looks like I need to make fresh copy of xp pro keep getting a i386 copy file error what next LOL
  • 63 Answers
Take out the graphics card to see if she will boot with the on board graphics. If not take out all but one stick of memeory to see if one stick is faulty try with them individually.
Posted on Jul 05, 2008
  • Matt Major Jul 05, 2008
    Sounds good so far, so now you can set bios to boot from cd/dvd and get your os installed.
  • Matt Major Jul 06, 2008
    Never give up!
How do I install my 22w2 to my Dell Computer with Windows XP 2002
Windows install first Available some points:-
A> Fresh Windows XP CD not damage cd, if cd damage may be some file miss and installation after problem show.
B> DVD Rom Drive.
C> You DELL pc support Windows XP.
Installation Process:-
> Insert CD to DVD ROM driver and boot CD.
> If CD not select first boot then open bios and select CD first boot.
> Then follow instruction step by step like language, which drive install windows (C Drive select), format option (select quick format), new user create etc.
Thanks..
Sep 06, 2013 | Westinghouse Electric LCM-22W2 Monitor
No power to usb or monitor ports
Yes, the motherboard has failed - its chipset to be precise. Time for a new one.
Jul 18, 2010 | ASUS M2A-VM (0610839149438) Motherboard
Installing new hard drive and monitor says
Turn the computer off.
Disconnect all the disk-drives, both "data" and "power" cables.
Disconnect the CD/DVD drives, both "data" and "power" cables.
Disconnect the 3.5" diskette drive, both "data" and "power" cables.
Turn the computer on.
Better? Worse?
Nov 01, 2009 | MSI K8N NEO2-F NFORCE3 250 ULTRA S-939 ATX...
Add Memory In Compaq Deskpro 6000 P2 Shuttle PC?
No, it is in the actual box which contains the power button. You'll need to open that box and take a peek inside. You will see something similar (not exactly the same) to what is depicted in this picture. Now, in your particular instance one or two of the slots will be occupied by memory-sticks.
That is where your memory will be inserted to add extra RAM. Now we need to find out what type of memory you have right now, because we will need to match it. Download this utility and install it onto your computer. Afterward open up the area for system-memory (Or RAM) and determine what type of memory you have. Is it DDR, DDR2, or some other type? Once again, we will want to try to match the speed, type, and possibly even the brand to ensure the RAM will work with your system.
Once you have that information head online to this website. Once it loads navigate to Computer Hardware>Memory. On the left select, "Desktop Memory." Afterward use the, "Guided Search" to narrow your search to the type that is in your system, that way you're looking at memory types that your system supports aiding you ever so greatly in your choice.
Now just to clarify. This will increase the system-memory not storage-space. With storage-space I mean a hard-drive which contains all your files, personal data, and the Operating System in your computer. If you want more storage-space we will need to buy you a new hard-drive. This won't be as difficult, we just need to know if you have ATA or SATA. Most likely you have ATA since your computer appears to be oldler, so I would recommend a Seagate ATA hard-drive from this website. Once the website loads navigate to Computer Hardware>Hard Drives. Afterward, on the left under, "Hard Drives" select, "Internal Hard Drives." Afterward on the left under, "Guided Search" select the, "Interface" type, "IDE Ultra ATA100." Afterward make a pick on a hard-drive that has the storage space you're after. (The only seagate doesn't have a lot of space, so the ultimate decision is up to you.)
So get back to us with your choice along with the information on your RAM and hard-drive types and we'll let you know if you made a good decision.
Feb 17, 2009 | Compaq DP 6000 LOGIC BOARD (322735001)...
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
My asus motherboard
change motherboard really this even can t ovclock it
Jul 12, 2008 | ASUS P5PE-VM Motherboard
Cd-rom drive
try to separate the ide cable. /
Feb 08, 2008 | Computers & Internet
Signal Cable Problem
Check the monitor plug that goes to the computer for bent pins. or try another monitor/or cable .
Jan 12, 2008 | Computers & Internet
Computers & Internet Logo
396 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
