Question about Ruud UBHC Air Conditioner
Filter Placement Ruud UBHA
Morning;
Purchased a condominium in Florida with a Ruud UBHA unit installed.
Owner had store bought filter duct taped to bottom of unit.
There does not appear to be a 'tray' system to slide filter in and out. I do see a slotted opportunity but appears that could only take the free form filter as there is not entry in from the side, only by forcing one in from the bottom.
Is there a missing tray that attaches to the bottom of the unit to house the filter?
Your help is greatly appreciated and your time well respected.
Thanks,
Brad
  • 20 Answers
Hey brad first you need to indentify wich is your supply and wich is the return after you have done that the filter is allways on your retun side however not allways is the filter set up at the air handler sometimes its in a duct sytemn on the ceeiling or wall hope you find it
Posted on Jul 23, 2008
Are the filters for my Ruud 80 plus furnace supposed to be installed vertically or horizontally?
Hello Donna Haslam
What ever EFECTIVELY BLOCKS all air
BEFORE it enters your heater...
Check out your air intake...
If this is the DESIGN EXERCISE it feels like...
Consider buying an INTAKE HOUSING
that takes a STANARD SIZE air filter.
FILTER...
AT THE INTAKE is a superior location
because it prevent dust & "stuff" from
EVER ENTERING your DUCT work.
Carnac
Carnac the Magnificent
Mar 19, 2017 | Ruud Heating & Cooling
Ruud ubha-21j00nuaa
Can you see the condition of the coil itself? If it is blocked this could be a cause for the frozen coils. Also, check the condition of the blades on the indoor fan. Dirt and dust accumulation on the blades reduces airflow.
Jul 14, 2014 | Ruud Handler Air Conditioner
Where is the filter and what kind is it so I can replace it
Just follow the ducts from the unit, filter is usually located in the ceiling or wall.
Sep 29, 2012 | Ruud UBHC Air Conditioner
Where is the filter in ruud model UBHC-21J11NFC
It depends upon configuration- or how it was installed.
In general terms, wherever the air from the structure is being drawn into the cabinet for air recirculation/intake- the filter will be in the vicinity of the ducting connecting to the Ruud heat pump/AC.. It will be before the "A coil" assembly (the copper tubbing with fins roughly the shape of an "A".
This assumes it was installed correctly. If not, the A Coil will collect a thick layer of dust on the side facing the incoming air flow.
The relevent Ruud documentation is here:
http://www.ruudac.org.ua/ubhc02.pdf
If there is any doubt about the integrity of the installation, contact an HVAC contractor familiar with your area to inspect and make corrections if needed.
Apr 11, 2012 | Ruud UBHC Air Conditioner
What size air filter fits model #UBHC14J06SFD? I was told by a tech that the original filter that came with the unit needs to be replaced. This was purchased back in 2004. The sizes that are sold in the...
Recommend a washable lifetime filter that can be custom fitted for your unit. There are many different brands of cut to fit and custom sized filters available.
The original filters supplied with the unit are usually washable as well although the manufactures are not including it all the time anymore.
Aug 21, 2011 | Ruud UBHC Air Conditioner
Just moved into a 40 year old house that has an RUUD model UGPH-07EAMGR furnace. Went to check the filter (which of course was loaded), and it was just sitting over the insertion slot. Suspect someone put...
The duct work on the return air can be made to accommodate any size of filter and it may not be the size the furnace takes. Some installers can cut a slot in the outside of the duct and put the filter there, bypassing the manufacturers method of mounting. I would measure the slot or mounting and see what comes close.
Jul 16, 2017 | Heating & Cooling
I have a UBHA 17J11 Nuda a/c unit. Where is the furnace filter?
Pull the bottom panel off and it should be inside.Russ
Jul 19, 2009 | Ruud UBHC Air Conditioner
I have a RUUD Achiever heat pump. Where does the filter go? I don't see a slot for it. I can't even tell what size filter it takes, since there is no defined slot.
it would be at the air handler portion of things (the unit inside) you might have to take off the lower door to access it it would be located at the bottom of the unit or somewhere in the duct work before that point look for spots that say airflow and will show an arrow--->
Jul 12, 2009 | Ruud UBHC Air Conditioner
There is no filter (was not installed) in the bottom of my unit (inside) air handler.... Why not? Now I am having problems...could this by why???
The new rheem and Ruud units have to have a filter rack installed in the unit. If it is an older unit the rack is inside the unit. You need to pull bottom cover of unit. I do not know why the new units do not com with filter racks and I have asked the distributor this question.Rusty
Jun 07, 2009 | Ruud Central System Air Conditioner
Filter,heat ducts,and best heat we can get from unit
As for a filter if there was one installed it will be somewhere between the unit and the inside livingspace and are the black plastic supply vents wrapped with insallation or not ,if not they are the wrong ducts if you need more help just e-mail
Nov 10, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
563 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
