I am installing a LITE ON sata dvd drive will I need drivers and if so will the drivers come with the device Anything else to observe
  • 98 Answers
No, you will not need any "special" driver for a DVD drive. Just plug it in and it will work. If it is a "retail" drive then DVD player software will come with it. You might need that software for the DVD video codec. OEM drives do not come with any software.
Posted on Jul 05, 2008
Windows 7 install stops and reports that a required driver for the CD/DVD drive device is missing.
you need to load the device driver prior to starting the install as it looks as if the windows installation drivers do not support your DVD drive. Get the driver on a USB stick and load it at the first of the install.
Feb 13, 2013 | Samsung DVD Burner SATA Model SH-224BB -...
Is it possible to update the firmware of the HL-DT-ST DVD-RAM GH22LS30 for use with double layered discs?
Install the latest chipset and sata drivers for your motherboard before you hook the sata DVD rom. Try hooking the DVD drive to another sata port, the HDD should be on SATA 1.
Make sure you've installed all the latest critical updates from Windows update. There's no chipset drivers available from Asus which means that the chipset should be supported by XP. Else the chipset in charge of the SATA controller is the SIS 964 chipset and you can find IDE and SATA drivers here : http://www.sis.com/download/. Can't hurt to give them a try but start with Windows update.
Refer to the motherboard manual to clear the BIOS settings (clear the RTC RAM in the manual).
What's the exact model of the hard drive and of the DVD drive ? Go to start => run and type devmgmt.msc. Expand disk drives and CD/DVD drives to find the model ID's.
While you're in the device manager check that there's no tagged device in the list (with a yellow or red icon).
Jun 17, 2011 | LG Computers & Internet
When I installed the Lite on Blu-Ray drive I plugged it into a SATA port on my Motherboard the computer would not boot. I have 4 SATA ports on my MB and I have my HDisk drive in the first port and my Sony...
Check the jumper setting on your drive the most common format for drive connections in old money was:-
IDE 0 - HDD 1 - Master
HDD 2 - Slave
IDE 1 - DVD1 - Master
- DVD2 - Slave
Not entirely sure if SATA configuration on m/boards are the same as the old PATA but would imagine the jumper principles are.
Apr 06, 2011 | Lite On DH-4O1S Blu-ray Burner
My internal CD/DVD drive and Burner quit working. Will not run a CD or DVD. Computer does not even recognize it as a drive. Can this be fixed or what kind of external drive can i get?
As I'm sure you are aware a CD/DVD drive is a mechanical device. It's 'lifespan' is rated in hours of usage. With the C521 being 4 years of age, I wouldn't think the DVD dual-layer burner drive would be defunct. Does depend on how much it's been used.
Ordinarily I would state cleaning the optical eye in the CD/DVD drive, and also reinstalling the drivers, if a disk is not recognized. However the, " Computer does not recognize it as a drive.", statement concerns me.
Suggest you try the software approach first of reinstalling the drivers, then if you wish go on to the hardware approach, of checking to see if the data, and/or power cable is loose on the DVD drive.
Reinstalling the Drivers:
The main method;
1) Left-click on Start
2) Right-click on My Computer
3) Left-click on Properties at the bottom of the list
4) Left-click on the Hardware tab
5) Left-click on Device Manager
6) In the Device Manager list, left-click on the + sign next to Disk Drives.
7) Now right-click on the name of the DVD drive.
Here you will have the options of either Uninstall, or Update Driver.
I suggest you left-click on Uninstall.
Update driver seldom works.
A warning will come up, "Warning you are about to uninstall this device, ya-da, ya-da"
It's okay. Click on OK.
Close all windows, go back to your desktop screen. Shut your computer down normally. (Start > Turn Off Computer > Turn Off)
Wait 1 minute, turn your computer on.
After Windows has loaded you should see a pop-up out of your system tray, "Found new hardware".
Plus perhaps another one, "Found XXXX DVD writer"
Still no?
Then it's time to check the above mentioned cables.
Your Dimension C521 uses a SATA optical drive. (DVD drive)
The Data, or Interface cable looks like this,
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
(The color of the cable may not be the same, and it may not have a 90 degree elbow connector)
It is a 7-pin connector.
Make sure it is plugged in tightly to the back of the DVD drive, and also to the SATA header on the motherboard.
NOTE*
BEFORE you reach inside your computer!
Computer unplugged from power, observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity.
Static will Fry Out (Short Circuit) the hardware components inside a computer.
Computer unplugged from power, working on a table, open the computer case.
TOUCH the metal frame of the open computer case, to relieve your body of Static.
Should you get up, an walk away in the middle of working on your computer, upon your return be SURE to touch the metal frame again.
Computer unplugged from power, you're safe. TOUCH the metal frame of the open computer case, your computer is safe.
Here is a link to Dell Support, and the Service Manual for the C521,
http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/index.htm
You will see - Removing the Computer Cover, and Replacing the Computer Cover.
In the main menu list you will also see - Technical Overview.
If you click on this heading, and then on - System Board Components, you will see the motherboard in an illustration.
Here you will see the Ram Memory slots. Below them is where the 24-pin ATX main power cable plugs in, (No.5), and to the right of the main power cable are two SATA headers, on the motherboard. (No.6)
Your SATA harddrive plugs into one of these SATA headers, and your DVD burner optical drive, plugs into the other one.
The SATA power cable going to your SATA DVD burner drive, comes from the Power Supply. It's a 15-pin connector. Looks like this,
http://en.wikipedia.org/wiki/File:SATA_power_cable.jpg
Be sure it's plugged in tightly to the DVD burner drive.
It could be a bad SATA Data cable.
More than likely your DVD drive is just toast. Seen the last of it's days.
Your Dimension C521 uses a regular size SATA DVD burner drive, even though it's a Slimline style of computer.
There are MANY drives available, should you decide to replace it.
You can also use one of these drives in an external enclosure. This way you just plug it's USB cable, into any available USB port on your computer.
If I were to recommend a SATA DVD burner drive, I would recommend one of the Lite-On models.
Cost less than most, but have features, and reliability of those that cost 3 to 5 times as much!
I'm using a Lite-On model that cost $48 from a large store, but could have purchased it for $28 online.
It's a DVD SATA burner drive that will support dual layer disks, and has LightScribe Technology.
Has lasted over 4 years now, and a clients computer that I installed the same model, has lasted over 5 years now.
Zero problems.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5204603&CatId=4
(I see they're cheaper now, sheesh!)
Barring you do not wish to open your computer, and replace your DVD burner unit, here is an example of a 5.25 SATA external enclosure,
(A laptop harddrive is 2.5 inches across in width. 2 and a half inches. A desktop harddrive is 3.5. An optical drive is 5.25 inches. 5 and one-fourth inches),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2414551&CatId=2784
If you have any questions please post them/it in a Comment.
Regards,
joecoolvette
Sep 08, 2010 | Dell Dimension C521 PC Desktop
Just installed an LG Electronics CT10N Slim SATA Blu-ray Combo Drive into my media pc running win 7. New computer so there arent any driver issues. I replaced a dvd burner because I wanted to experience...
Was going to leave this question? Normally computer will react that way when a blank disk that is not formatted is put into the drive. The blank disk then requires formatting and will function. Not sure if this answers your quesiton. Sorry.
Dec 31, 2009 | LG Electronics CT10N Slim SATA Blu-ray...
How to install Redhat Linux 4.0 on Acer Power Series with SATA.
So did you try to install with and IDE dvd drive? Might be a BIOS issue, update bios or get a ide dvd drive somehow...
May 06, 2009 | Acer Computers & Internet
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
LG GH22 dvd writer - not reading
I had the same problem with the GH22 Internal drive on vista. Assuming this is the only cd drive you have, just go to the device manager and remove/uninstall anything under "DVD/CD Rom Drives" then restart. It should get picked up and recognized properly. It took a couple of restarts to work. For refrence, I only have the LG GH22NP20 installed, what appears in device manager are 2 items... (1)HL-DT-ST DVD-RAM GH22NP20 SCSI CdRom Device... (2) KU1051Q EAG855E SCSI CdRom Device... Incase you have multiple cd drives, this should help tell em appart. Enjoy. IDK399
Jan 20, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
Dvd not seen by XP
plz check the manufacture website for the drivers
Dec 09, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
