TRIAX DVB2000T set top box cannot find any channels today. have checked aerial seems ok.the box is now about 5 years old and has never let us down before
Did a search and found out that my digibox along with some other makes are no longer able to receive any channels because of an update by Freeview.This has resulted in thousands of people unable to receive any programmes at all in Scotland as their signals are all digital in some regions,I live in Durham and the changes have already reached here.This is being rolled out down the country over the next week.
No doubt we will not hear anything in the news about this change untill it reaches London,then people will be concerned.
Posted on Jul 06, 2008
Why is my Humax 4000 very slow, freezing and scrambled saying bad signal.
Check the signal level and quality. Reseat all aerial connections.
Jun 18, 2016 | Humax Televison & Video
Tip
Digitial channel tune in and set up
if you have a problem getting digital channels (uk) find local channel number digital uk can help enter tuning menu go to manuial tune on tv or digi box. it will ask for channel number start with highest number pess ok or search repeat for each channel number normal 4or 5 depends on aera if still not getting all channels put aerial lead which come for aerial into tv bypassing any equipment such as vcr/dvd recorder then start again if still not all channels may need aerial upgrade .if yo get all channels connect vcr/dvd if some channnels disappear need to reset RF out on vcr/dvd remove aerial .connect vcr/dvd via scart reset RF out on vcr/dvd this can be found in vcr/dvd set up menu reconnect all leads should now work ok
Note do not set RF out to any digi channel numer
on Aug 17, 2010 | Televison & Video
How do i connect my set top box to my digital tv
Ok, I am confused. How old is the TV? If new, hook the ariel directly into the tuner on the TV. The ATSM tuner in auto configure will identify and setup the channels with no need for a set top box. On old TV using an Analog Tuner will need a box. Antenna in goes to the antenna, antenna out goes to the F connector on the TV. Should be one coax connector on the TV. That is an F connector. Set the TV to channel 3 or 4 depending on what the switch is set on the back of the set top box.
Nov 16, 2013 | GPS
My daughter has a Goodmans GTVL19W17HDF in her bedroom for two or three years. She has only now mentioned that she has now lost ITV1 Channel 4 and Channel 5 using DTV, and also has a very inconsistently...
Fisrt check that the aerial connector going into the TV is OK.
The UK is in the process of switching off the analogue channels and reassigning to digital TV. This means that the signal strengths of various transmitters are getting stronger and channels are moving around to different frequencies. Try retuning the digital TV stations. If this does not work then try an external DTV box to see if the TV is at fault or it is a bad signal on the aerial.
May 16, 2011 | Televison & Video
DMR-EX75B - tuning gone with clock
Check that C1801 is not leaky. If so, check if IC1801 has blown. If it has blown, it will also need to be replaced.
Usually it's only C1801 leaky, replace it and thats it.
You can find the capacitor on the main board, under the digital board that has ribbon cables going to the dvd drive.
Hope this helps.
Mar 04, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
How to connect settop box to tv with no avs
You will have 2 UHF plugs on your set top box.. One for input (aerial) and 1 for output (TV). Connect your main aerial to set top box UHF input and connect an Output UHF lead from set top box to TV. Next switch on set top box and retune tv on a spare channel until you get set top box channels (good idea to switch on menu on set top box so you know you are tuned into set top signal )
Feb 12, 2010 | Philips Televison & Video
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
In London, Uk. I have poor reception of channel 5. have got recently a one for all powered aerial. how do I set it up? Model sv-9140-00-002
Your reception would be much improved by using a free to air digital set top box - only about £20. If you are in east London especially near docklands channel 5 reception with a conventional aerial gives a lot of problems. sv-9140-00-002 is an interior aerial booster - I doubt whether this will improve things much. Best solution is a good outside aerial - if you live in flats is there no communal aerial available?
Mar 17, 2008 | Televison & Video
Troble tuning in
If your recorder is hooked up after the cable box, then it can probably only receive channel 3...the set-top box does the switching, and sends everything to the TV (and recorder) on Ch. 3
Sep 25, 2007 | Samsung DVD-HR720 DVD Recorder
Open Questions:
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
