Question about Ericsson Cell Phones
Phone not ringing when incoming call coming through
  • 983 Answers
The speaker inside might have missed the contact with the circuit board inside or the speaker is gone ...
if you are good at opening then just open it if the speaker has missed the contact then just refit it correctly so that it touches the circuit board or if the speaker is dead then replace the speaker solves the problem .....
(dont get confused there will be 2 speakers in the handset one is ear speaker & another one for the loud speaker or for hearing the ringtones etc)
if the same problem persists then there is some problem in the firmware so give the restore factory settings(reset) ..
all your firmware problems will be solved ....
this firmware problem may be due to some reasons like removal of the battery when the phone is turned on or due to the sudden turn off the mobile when the battery charge was low or may be due to some virus attack ..etc ..
so by giving the restore factory settings it will get fixed ....
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Posted on Jul 05, 2008
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
We have a Toshiba phone system DKT2010 and I need to reprogram
try to decrease to volpum of ringging
other wise ask the vendpr to reassign the incoming ringging group for yr 3 incoming lines
Apr 13, 2009 | Toshiba DKT3010SD Corded Phone
Line 4 doesn't ring in coming call
The way 4 line phones work is that you need 4 lines on every jack that is connected to your phone.
You see the light probably because one of the phones has line conected and you see line appearance.
Mar 20, 2009 | Nortel Lands Phones
Some phones light up but there is no ringing...
is the ringging assignment setting
means downstair phone been set for incoming ring, so u can see the indicator ligh on and ringging
up stair dint assign a incoming ring so that u only can see the indicator light always blinking w/o ring...
contact yr phone provider to set the ringging assignment
Feb 24, 2009 | Toshiba DKT-2020 Corded Phone
Choosing which lines ring.
If you have a multi line setup, you have a phone router. Have your phone company come in and program it for you.
Feb 17, 2009 | Toshiba DKT-2020 Corded Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Nov 19, 2008 | Nokia 3120 Cellular Phone
Trying to Transfer a Line to Ring at anothers desk after 4 rings.
When my boss is on the phone she wants all incoming calls to bounce to my line. or ring so she knows an incoming call is coming. what can we do?
Aug 29, 2008 | Mitel Superset 4025 Corded Phone...
Intermittently my iPhone does not ring and incoming calls get forwarded.
Through the iPhone to dustbin and buy a normal phone. It works better than this iphone. This happens to a lot of people.
Jul 14, 2008 | Apple iPhone Smartphone
Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Carl
Jun 03, 2008 | Panasonic KX-T7731 Corded Phone
Cell Phones Logo
176 people viewed this question
Top Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you an Ericsson Cell Phone Expert? Answer questions, earn points and help others
