Hi I just bought a Wharfedale DTR250 twin tuner HDD. How can I connect it up to be able to record sky programmes? On my old VCR all I did was set the VCR to EL1 and the selected Sky programmes recorded OK. The manual is poor and Argos not coming up with any answers. Thanks Bill.
My solution was to return item to Argos, got my money back and will now go ahead and order a Sky Plus Box. Apparently these type of Recorder will not record Sky programs!!
Posted on Jul 09, 2008
Sky plus is playing up on our set up. It will not let us access the recorded programmes for long periods at a time it can take up to half an hour to get it to play sometimes we give up cos it just isn't...
hello it sound like it need a software up date here is what to do unplug the power lead at the back of the sky box .on the front of the sky box is a button called backup. press hold the backup button while doing this plug the power lead back in you should get a message saying do not disconnect the the power
regards
shaun
May 19, 2010 | Televison & Video
HDMI quit working with store bought DVDs
so you have to update a new firmware and then it will be ok
Dec 20, 2007 | Toshiba 52HMX84 52" Rear Projection...
We have a Sam Sung HDTV. Suddenly after one year of use, we can no longer play our VCR/DVD recorder/player. The screen shows weak or no signal. We have tried two other players with their cables back and...
It could be the internernal cables or solder joint connections to the video input or tuner board. you can test each capacitor with an ohmmeter to see which one is bad. They should be 25-30 ohms.
Oct 26, 2009 | Televison & Video
Code to programme Sky Remote to operate new TV?
i have the same problem with the codes 0035 0125 0049 everything works except turning the volume up. have you found a solution yet???
Dec 31, 2008 | Televison & Video
I cannot record a show onto a blank vhs tape in my vcr??
Initially, pls verify that the coaxial cable is connected to the ANT/Cable/RF IN of the VCR. Thereafter the built-in tuner of the VCR would be used to select the desired channel to be recorded. The VCR in turn maybe connected two (2) ways to the TV:
  • Audio/Video using yellow, red & white RCA cables/connectors using AV1 or Video1;
  • RF patch cord from RF OUT of VCR to ANT/Cable/RF IN of TV using either Channels 3 or 4.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Televison & Video
Tv runs through vcr only. What can we do? Also need a manual. Where can we find one?
try to resolder the tuner first and see if that makes a difference , otherwise you may need to replace the tuner
does video inputs work ok?
Nov 07, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Sky Plus Planner shows message Please Wait and nothing happens. Cannot therefore play previously recorded programmes or record new ones.
try formatting your hard drive, you will loose all the saved programmes but it may fix ur problem.
follow instructions:
http://nice-design.co.uk/blog/sky-plus-system-fault-how-to-fix-faulty-sky-without-a65-callout-fee
Oct 28, 2008 | Televison & Video
Can't tape tv program on VCR while watching another show on digital cable.
If you set it up right per Comcast instructions:
Your VCR will record a show off of its built in tuner while you are watching another show from the cable box.
Make sure that the AB switch is set into the correct position and that you are only recording a show that that isn't digital. I believe you can only record shows up to channel 150 off the VCR tuner. Anything higher than that won't work.
If your Comcast Cable Tuner has two AV outputs in the back of it, you can skip the AB switch altogether and plug the one of the cable tuner output lines into the back of the VCR input lines. That way it can record that show you are watching on the cable tuner at that same time.
Jul 19, 2008 | Televison & Video
WHARFEDALE LCD2610AF WHEN I TURN ON DIGITAL I HAVE PERFECT PICTURE &SOUND.AFTER 10 TO 30 MINUTES THE PICTURE FREEZES AND THEN SCREEN TURNS WHITE WITH AGREEN HORIZONTAL BAND LOWER HALF OF SCREEN.WHEN...
Hi.
If the picture & sound are ok in analogue mode then chances are you have problem with digital tuner.
This may be expensive to repair so I would advise connect external freeview box or sky etc to get digi channels using scart to connect to your TV.
Jul 16, 2008 | Televison & Video
I can not record any tv programs because my vcr does not have a internal tuner so how can i fix this problem?
If the VCR has no tuner, you must have another tuner connected (such as a cable or satellite box) in order to be able to record anything. This tuner will then select the channel to be recorded.
Apr 21, 2008 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
