Question about HP LaserJet 4600 Printer
What is the cause of a 51.2M error on a HPLJ4600 color printer
  • HP Master
  • 2,386 Answers
Hello
According to HP following is the remedy for this error
  1. Turn the printer off, and turn it on again.
  2. Remove the surge protector or Uninterruptible Power Supply (UPS) and connect the printer directly to a power source.
  3. Try a different power cord.
  4. Try a different electrical circuit or outlet.
  5. Inspect the fuser for media or damage, and reseat the fuser.
    1. Open the top cover.
    2. Locate the green square tab on the right of the fuser flap and lift it to inspect the fuser roller for media or damage.
    3. Unscrew two blue knobs located on each side above the control panel.
    4. Lift the fuser by grasping the fuser housing above the green arrow on the left and right.
    5. Reinstall the fuser.
  6. Perform a cold reset on the printer.
    1. Turn on the printer.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green what is the cause of - c00224695.jpg (Select) button.
    4. Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  7. If this message persists, contact an HP-authorized service or support provider. Hope it helps, if so do rate the solution
Posted on Dec 24, 2010
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
Error 49.33.03
First turn off the printer and then delete the job held at the computer in the print queue. Then turn the printer back on. The error should go away. Try printing the document again to see if the error returns. Normally a corrupt print job causes this issue. If the error appears with no jobs being sent to the printer then the formatter board is most likely bad.
Mar 10, 2014 | HP Color Laserjet Enterprise Cp5525n...
We have an HP 3550 color printer that has a 50.1 Fuser Error. Will replacement of the fuser correct the problem?
The most common reason that causes a fuser error is its failure to reach operating temperature. If the fuser area can be accessed, check to see if there is noticeable heat present. If not, the fuser may not be getting the required voltage to bring it to temperature and you may need technical help to determine the exact cause of the error.
Aug 24, 2010 | HP Color Laserjet 3550 Printer
I have this error code on my ricoh aficio cl7200 : SC 440-02
On the CL7200, sc440-02 is a color drum motor error. This error could be caused by a bad color drum unit (any of the 3 colors) or the drum gear positioning sensor, but more often than not it is because of a drum motor that went bad. There is one motor that controls all three color drums -- when this motor goes bad, you get the sc440-02 error.
Apr 23, 2010 | Ricoh Aficio CL2000N Laser Printer
Error 49.4c02
error 49.4c02:
Printer Error 49.XXXX - A critical firmware error has occurred. - - Turn the printer OFF then ON. If the error continues, then contact HP Technical Support.
Generally speaking, this error will occur if you are using an outdated firmware build.
Don
Nov 18, 2009 | HP LaserJet 4600dn Color Printer
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 12, 2009 | HP Color LaserJet CP4005dn Network Printer
HP Color LaserJet 4500 Printer
Here is your problem. Hope that this helps you.
54.1 PRINTER ERROR
Description:
Indicates that an internal power failure has
occurred.
Action:
1. Turn the printer off, and then turn the printer
back on.
2. Replace the high-voltage power supply.
3. Check the fuser to ensure jams have not
occurred.
Caution When clearing jams, the
thermistor can be damaged
causing this error.
4. Make sure there is not a fluctuation in the
power supply to the printer. Check that the
electrical specifications (see Chapter 1) are
met.
5. Replace the low-voltage power supply.
Apr 02, 2009 | HP Color LaserJet 4500 Printer
I have a Lexmark C510 and it's giving me an engine error 994. What do i do? I need your help.
here is an excerpt from the lexmark technical tips library it could be usefull
Bulletin Summary: 994 Density Sensor Error
Document Date: Feb 03 2004
Operating System: Printer Based
Issue:
The 994 Density Sensor Error can be caused my many different things. The basis of the Error comes from the printer not being able to do the auto calibration and the auto registration when the printer is turned on. Toner Patches are written to the belt on ever Power Cycle of the printer or when ever a door or cover is opened on the printer when the Auto Color Adjust is turned on and the Auto Registration is turned on. If too much of one color is placed on the belt or there is an absence of a color or all colors the printer will call the 994 Error. This error will also be called if the activation arm for the density sensor is not pushed in. Another thing that can cause the 994 Error is if the sensor for the under the belt for the BUD Clutch positioning is the incorrect part.
Solution:
Things to Try with Customer
When the printer is powered on in Diagnostics the printer does not perform the Auto Calibration of Registration functions as would normally occur on POR. Turn the printer off and POR in Diagnostic Mode. From here print the Quality Pages under the Print Tests. These quality pages can give insight as to what is causing the 994 error.
What to Look for on the Print Quality Pages
First Look at the First Page on the Print Quality Pages. The first page tells mean things about the printer. There is a section that gives the Page Count on the printer, the Last 12 Errors, the Serial Number, Engine and Rip Code Levels. There is also a section on the first page that tells the last time the printer did the Auto Registration and Calibration. If the printer does not have 703.007 RIP on a C910 or IBM 1228 Printer this may not be displayed. Since there is only one Version of RIP on the C912 and IBM 1357's 720.013 this code will display the last time the printer was did a calibration and registration.
Second - Go through all the Quality pages are any of the color planes missing completely?
If only one color plane is missing it's possible that LED array is unplugged.
Is the top half or bottom half of one or more color planes is missing completely?
If yes then that one LED or Multiple LED's May have one Cable Unplugged.
Are all the Color pages white but the black pages printed ok?
If all the colors are missing and only black appears most likely the sensor under the Belt for the BUD Clutch position sensing is the incorrect part. This would only be the cause if that sensor was just replaced during fixing a 994 Error. Another check to do if this is the case is to look at the belt while it's in the printer. Open the Top Cover of the printer and check the right and left sides of the belt. The Belt should be raised on the right side and be equal height as the left side. The pictures below show the Belt in the Up and Down Position. If the belt is down when the printer tries to do the calibration no color will get transferred to the belt. This will cause the 994 Error. This also is why no colors would be appearing in all the planes but black is fine.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 01, 2008 | Lexmark Office Equipment & Supplies
Konica Minolta Magic Color printer
The drum error could cause the printer not to work.  What's the copy count on the machine?
Sep 19, 2008 | Minolta C250 Color Copier
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP LaserJet 4600 Printer Logo
    1,468 people viewed this question
    Clive
    Clive
