Question about D-Link Computers & Internet
Network link down
While working user 1000 machine but 20 user just 1 minutes not getting internet connetion simultence time.
what is this problem?
do you have any solution for me?
    Sergeant:
  • 221 Answers
You need to log into the router and make sure that NAT is enabled. Nat allows simultaneous connections to the internet while using only one outside Ip address. Actually the correct term is Overloaded Nat, or Pat, but commonly on D-link routers this is called NAT. Start there and let me know what happens.
Posted on Jul 12, 2008
Tip
Speed UP FireFox,Opera,Internet Browsers 10times Faster FOR...
Speed UP FireFox,Opera,Internet Browsers 10times Faster FOR FIREFOX USER
Follow my instruction very carefully ok?
1. Type "about:config" into the address bar and hit enter. Scroll down and look for this
Set this to true by double clicking them :
network.http. pipelining
network.http. proxy.pipelining
2.Then search for this :
network.http. pipelining. maxrequests
Double click then set it to some number like 100. This means it will make 100 requests at once.
ALMOST DONE!! right click anywhere and select ->NEW->Integer Then name it as
"nglayout.initialpa int.delay"
and set its value to "0". This value is
the amount of time the browser waits before it acts on information it
recieves.
FOR INTERNET EXPLORER USERS
1. Click start> run
2. Type regedit> enter
3. Browse folder HKEY_CURRENT_ USER\Software\ m*cro$oft\ Windows\Curre ntVersion\Internet
4. Right click at windows right > New > DWORD
5.Type MaxConnectionsPerSe rver> u can set value (the more higher the
no, the more good speed u get, eg : 1000) by right clicking on
MaxConnectionPerSer ver>Modify.
6. Create another DWORD>type MaxConnectionsPer1_ 0Server
7. Then put a high value as mentioned above
8. Then,Restart Internet Explorer...
Opera
1. To speed up internet browsing in Opera, go to Network under Preferences, and set Max connections to a server to 16, and Max total connections to 20.
2. Users of old computers should probably turn javascript off by default unless a page requires it. This is one of the biggest slowdowns for web page loading, since Java, and Javascript can be very complex, and take a long time to load. Remember F12 toggles these settings easily and quickly.
3. Put the cache on a drive different to the one your operating system is installed and keep the drives well defragmented. A good idea is to put the cache directory on a flash disk. To put the cache somewhere else, add the following line to the [User Prefs] section of opera6.ini:
Cache Directory4=your\path\here
You can find the opera6.ini file in C:\Documents and Settings\user\Application Data\Opera\Opera\profile.
4. Favicons will use resources, if you need absolutely minimal resource usage, turn them off. You can do this by going to Tools -> Preferences... -> Advanced -> Browsing and selecting Show no icons under the Page icons section.
5. Use standard windows skin, and disable special effects, which will save a few CPU cycles.
6. One more thing. You can change the process priority of Opera to get a further enhancement (set to high). Do this only if you are not multitasking with other apps.
on Dec 14, 2009 | Computers & Internet
All lights are active and green except for the internet light. This is the only red light. What can I do to fix this?
Call you ISP as your user ID and or password in the ppoe or settings was rejected or there DHCP server is down so check with your isp and see if there having issues there more the likely are if not unplug the modem and wait 30 secounds if you get the red light again and it does not change for more then 15 mins to 1 hour your DHCP on the isp end is down. You connetion to the Dslam and or ATM is working but the DHCP server that authencates you on the network via static or ppoe routes has been severed. You need to call them.. Thanks please give me those 4 big thumbs up for unwavering support to your FREE question today!!
Nov 24, 2009 | 2wire (1000-400108-001) Router
Home networking Windows XP
Often this is a simple power management issue. On the laptop check the wireless properties and disable allow Windows to turn off this device to save power.
Apr 05, 2009 | Microsoft Windows XP Professional
I have a 2wire att router that loses internet connection
try this it worked for me. If you use Chrome go to tools, options, under the hood and un-check Predict network actions to improve page load performance, I have no idea why this worked I just know that I have not lost my service since I did this. I stumble around a lot and was always getting the message no broadband service or something of that nature. One time chrome suggested that I try this (no idea why chrome suggested this) so I unchecked the box and now I no longer have the problem of loosing my connection. I was loosing my connection a lot 10-20 times an hour.
Good Luck
Feb 28, 2009 | 2wire (1000-400108-001) Router
Router Loses Connectivity or "Locks Up" over time.
supposedly the firmware 1.03 was suppose to fix this. However, I still have the problem and when i try to unplug the power to the router and plug it back in, then it often times just lights up all the lights solid and refuses to work. I have to unplug it again and again to get it to work.
It usually will work for a few weeks at a time then have a really bad day where it locks up every 10min to an hour. Gets really annoying.
Sep 28, 2008 | D-Link 802.11g Wireless Router WBR-1310...
I restored my modem and I lost my verizon connection
Ok there are few steps to solve the problem
  1. goto My network places and make the connection
  2. double click the make new connections and select which country and enter zip code of your country. and select tone or pluse.
  3. enter the new connetions.
  4. After finish that the window comes like welcome to network connections wizard.
  5. choose which connetions you are using like dial up or boardband connetion which high speed
  6. follow the wizards and select the region and connetions of which type internet and zip code.
These are modem connetions of intial part of the connecting the internet.please inform me any other .
Apr 30, 2008 | Computers & Internet
Connet my home pc
obviously, you cannot use a cable to link up from your office network.
1 know your provider and the kind of WAN service offered
2.Get a router that is compatible with your office network and configure your router with similar priorities with that of your officce network(a wireless radio might be require)
or if you are not vast networking,invite a network administrator to do it for u
Apr 14, 2008 | Computers & Internet
Psp dns failure
How is the machine connected to the Internet? Modem, cable or ADSL? Or are you using it at work through a company network?
Jan 06, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
174 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
