In windows shows all files also the system files and then check your memory card and delete the files. Or you can connect your memory card to a mac or a linux to see all files also the hidden.
connect your camcorder to the computer without the memory stick. then go to 'computer' you should see there the internal memory of your camcorder then open it and 'copy' all the files to your computer and put them on your memory stick.
Stick the memory stick into the USB port, next wait for the instructions, open my computer next select the memory stick open it, finally select the file you need to copy to the memory stick, and dump them in it
How "full" is the hard-drive? Perhaps, you could have only a few gigabytes to be "saved".
Click Start
Click My Documents
Click Edit
Click Select All
Right-mouse click on any of the highlighted items.
Click Properties.
Windows will report on the size (megabytes/gigabytes) of all the selected documents and folders.
Perhaps, you can buy 4GB or 8GB or 16GB USB memory-stick,
and manually copy your 'My Documents' files/folders to that memory-stick.
Or, use the "Windows Files and Settings Transfer Wizard" to "collect" all your files & E-mail, and write an "export" file to that memory-stick.
Then, on the "new" computer, run the same Wizard, and "import" from the USB memory-stick onto your new computer.
There are certain folders that the PSP puts on the stick when it formats it. Format the new stick on the PSP first. Then, you can transfer you files to it.
YOU CAN DOWNLAOD RECUVA FOR FREE THIS SOFTWARE WILL RECOVER LOST FILES FROM MEMORY CARD, HARD DRIVES EVEN IF YOU HAVE DELECTED THE FILE IN IF IT CURRUPT,, ONCE YOU HAVE RECOVERED THE FILE, YOU SHOULD REFORMAT IT BY GOING MY COMPUTOR RIGHT CLICK ON IT THEN GO TO FORMAT THEN JUST REFORMAT IT , THIS WILL RESET THE STICK AND WIPE IT
4gb is not enough space to hold the entire My Documents directory unless you have an extremely small amount of data in it. If you take many photo's it wont be long before My Documents is too big to fit. Suggest that you back up this directory to a set of CDs or DVDs,
If you want to update a memory stick just copy My Documents from Vista to the memory stick. Vista will ask if you want to overwrite. Click [on overwrite all] and the job is done.
Many cameras will not let you write to the card. Try using a card reader, which will make the memory card appear to the computer as a separate hard drive.
Dear LisaLu,
If the file extention of picture i.e JPGE has been changed, camera wont show that picture.
You should paste those pictures in same folder of cyber-shot.
