Question about Acer Aspire™ T180 PC Desktop
Lcd srceen moved computer today when plugging back in the lcd screen has no power to it at all. There is a wee box on the way to the lcd screen it has a little light in it that was not going either is the problem coming from there or is the lcd screen broken
  • 550 Answers
First check the wall socket, plug in a lamp or something
the transformer/power-supply unit may have failed(no little light) but since this is first connection to a different point there may be a popped breaker or fuse on the wall socket
Posted on Jul 05, 2008
Relisys picture problems
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options.
Customer Support
Sep 18, 2012 | Computers & Internet
Within the last few days the moniter "blue light" when it is turned on suddenly turns yellow and the screen goes dark. I move the mouse briskly and turn the moniter off and on again and...
You should check the "Power Options" when the computer "Sleeps" & "Hibernates". Go to the "Control Panel" if you Win 7 or below, if you have Win 10 just type "Power" on the "Search Box" on the bottom left of the screen and then click "Edit a Power Plan" and set when the Computer "Sleeps" and when it "Hibernates". Basically when you move your mouse you are waking up the Computer from "Sleeping" or "Hibernating". Goodluck.
Dec 14, 2017 | Acer Brand ACER P191W 19" LCD Monitor
I have an LG L1952HQ LCD monitor that shuts off every 5-10 sec. it's not the PC going into power saver or srceen saver mode
greatatuin1, Tell me the "date of manufacture" from rear of unit!! You may need to inspect the units power supply printed circuit board or black-brick switchmode power supply. Is power supply "lay on floor" type or internal to monitor case? Is your pc working ok with "differerent" monitor?? Have you been to youtube to watch "refurbishment" DIY videos of cold cathode-fluorescent-lamp back-lit lcd monitors??? If unit is really old and has lots and lots of "on" hours, you may even need to replace the CCFL lamps also. Tell me more info, so I can advise you. Symptom seems to be "black screen of death" !! Have you performed or even know the "flashlight test" that every ccfl lcd monitor owner should know??? Do additional comment back to me. 12fixlouie
Oct 24, 2010 | LG Computers & Internet
The srceen stays black
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Sep 06, 2010 | HP Compaq Presario V2000 Notebook
Screen reads no sync when I plug it into my lap top what does this mean
my lcd srceen reads NO SYNC when plug into my laptop, what does thi mean
Feb 07, 2010 | Microtek C893 18.1" Flat Panel LCD Monitor
Lcd srceen
This sounds like screen burn, or image persistence.
Jan 05, 2009 | Sharp Televison & Video
Asking for a password without one set
remove the bios battery and start computer. Switch off and replace battery. The password prompt should dissapear after doing the above. Hope this helps.
Dec 03, 2008 | Toshiba Satellite A135-S2246 Notebook
No light on srceen.
It usually means that you need new LCD screen or if the screen works and you just don't have a backlight go to Settings>Backlight>On (or 30 seconds or 40 seconds etc.) hope this helps. =)
Feb 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Broken Lcd screen
I have a perfect LCD s800 screen .Camera lens is broken . Dawdle to change if you have a wee star screwdriver..take out the casing screws ..back comes off ..another 4 screws takes the screen out. then the fiddly bit is the ribbon connector..screws back in and fixed . let me know if you want to do a wee deal. Ali
Apr 30, 2007 | Samsung Digimax S800 Digital Camera
White screen covers desktop
Ah A simple one. simply unplug the power adaptor and take itno a repair place or radio shack and ask them to measure the output to see if theres 12 volts DC on the plug?? Good Luck
Jun 14, 2006 | Princeton Digital LCD17 17" Flat Panel LCD...
Acer Aspire™ T180 PC Desktop Logo
132 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
