Question about Blitzz Technology BWA711 (B3WL000900) Wireless Router
Cant get internet on ps3
My ps3 says it can find the tp router and get ip address but can't get to the internet due to a dns error?
Lights on my router are green so thats working ps3 says signal strength 98% sometimes 100%.
  • 2 more comments
  • bense182 Jul 07, 2008
    hi thanks ive tried that but still nothing. ive plugged ps3 straight into modem and still nothing. could it by my motorolla sb2400 modem?
  • bense182 Jul 08, 2008
    How do i open ports and which would i open?
    Im using modem at the moment to connect to internet so modem does work.
    Ps3 has never worked with modem why i tried it with a router.
    router is a tp link wr841nd. Im online with router aswell.
    My ps3 can obtain an ip address and says internet connection succesful sometimes but i need to update my ps3. go to update software says dns error.
  • darius25 Sep 15, 2008
    mine does 2 it either says ip address has timed out or dns error
  • roaddog17 Feb 21, 2009
    Can anyone help me get Nat 2 on my PS3?
    Novelist:
  • 143 Answers
Make sure that the ip address that you are getting is a valid one and you are connected to the correct wireless network. for example, if your router's ip address id 192.168.1.1, your computer should have an ip address of 192.168.1.x. if you are getting a valid ip address and you're still getting the dns error, the thing that you can do is set a static ip address and dns to your ps3.
if you don't know the dns to use, go to the command prompt and type ipconfig/all and it'll give you a list that'll contain the dns servers. copy the dns and enter it on the ip settings of your ps3 together with the default gateway (ip address of the router), subnet mask (it's usually 255.255.255.0) and your ip address (make sure that the ip address that you'll set on the ps3 is not being used by any of your computers)
hope this'll help you and just ask me if your still having any problem
ciao!
Posted on Jul 07, 2008
  • aila tanada
    aila tanada Jul 08, 2008
    it could be possible that it's a modem concern but have you tried connecting a computer directly to the modem and check if you'll have internet access. if you do have internet access using a computer, most likely that you need to open some ports in order for the modem to allow access to your ps3. but if your computer is also not able to connect to the internet, it could be possible that the modem is not properly configured to provide internet access.
    just some clarifications: was the ps3 working properly before with the modem? what is the model of the router that you are using and are you online using the router? and what is the ip address that you have set on the ps3?
    ciao!
  • aila tanada
    before opening the ports on your modem, you can try first this step: go to your ps3 settings and turn off "media servers" (Network Settings > Media Servers > Disabled)
    i'll not be able to provide you a step by step solution on how to open ports on your modem and i'm not one hundred percent sure if the modem has that option since i was not able to find a user guide for your motorola sb2400 since it's not listed under the motorola products. usually all you need to do in order to access the modem's page is open a web browser, using a computer that is directly connected to the modem, and the type the ip address of the modem. once you're on the modem's page, look for "port forwarding" or "port triggering" and it'll ask you for the ports to open. if it'll ask you for an ip address, type the ip address that you have set on your ps3. here's the list of the ports that you need to open:
    Playstation Network Required Ports
    TCP 80
    TCP 443
    TCP 5223
    UDP 3478
    UDP 3479
    UDP 3658
    Remote Play & Gaming Required Ports
    TCP 80
    TCP 443
    TCP 5223
    TCP 9293
    TCP 10070-10080
    UDP 3478
    UDP 3479
    UDP 3658
    UDP 10070
    just in case opening the ports will not solve your problem, try to look for "dmz" and enable it. that'll open all the ports on your modem. you can also try to disable "upnp" feature if it'll allow you. if above steps are not able to fix your problem, you can try to update the firmware of your modem or contact your ISP just in case there are other firewall on the modem that'll affect the connectivity to your ps3.
Error when connecting to the internet: error (80130804).
This means that your PS3 is not able to get an IP address from your wireless network/router. I would suggest set the IP address manually on your PS3 including the DNS IP address.
May 11, 2010 | Sony Playstation 3 (PS3) Console
Hello, can you help, on my ps3 it keeps coming up with error 80710102 and will not connect to the internet or find the wireless box
This is a common dns error with playstation.
try entering the following in your ps3. Settings - Network Settings - internet connection settings - custom - wired or wireless depending on your internet - manual settings - IP address manual - enter your ip address and your router address and change your dns primary
Mar 17, 2010 | Sony Playstation 3 (PS3) Console
Cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
Jan 31, 2010 | Computers & Internet
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
.trouble with playstation 3 getting on line through router...
It looks like there are a lot of DNS servers that do not work correctly with the PS3. Below I will list a few DNS servers that do seem to work and you will need to manually configure the DNS settings for your PS3 to any of these addresses.
208.67.222.222
208.67.220.220
129.250.35.250
129.250.35.251
4.2.2.1
4.2.2.5
Nov 01, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Internet connection failed but IP address obtained.
Check to make sure that your router has gotten an IP Address from your ISP. Because you PS3 is telling you that it has an IP from your router. This means that the Router to PS3 connection has layer 3 connectivity, but what about from your router to your ISP? check that in the router by logging into the router's web page and going to the status page it should have your information from your ISP if it does not make sure that the main page is set to the proper settings either get IP automatically (Cable Modem) or Get PPPOE (DSL) connection (Make sure that your password information is correct to).
Now after checking these items make sure that you set the router up as the DNS for your network buy setting this on the status page then in your PS3 (set the DNS setting to point to your router, and set your router up as a caching DNS server).
Then power cycle the router after saving everything, and power cycle your PS3 after setting everything. This should clear up your problem.
Thank you,
Shuttle83
Oct 24, 2008 | Linksys Wireless-G Broadband Router
DNS ERROR
make sure you have a stable internet connection, DNS error means that the internet system cannot translate a name into an IP address and that normally means that the data feed going from your internet connection to the Playstation is going in and out and it cannot complete the upload of information required to access the internet, the problem most likely lies in your router or modem or any other wireless signal producer and it is very unlikely that it is related to the bluetooth connection in the PS3 itself
Sep 10, 2008 | Sony Playstation 3 (PS3) Console
Dns error when connecting how do I fix this
Unstable connection. if you have wireless connection that could be a problem depending on your environment. Try turning off your firewall too by calling your internet server(Comcast,DSL,etc.)
Jul 31, 2008 | Sony Playstation 3 (PS3) Console
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Internet fails from dns
To access the internet from a home broadband network you need the router appropriately configured on the WAN or internet service provider (ISP) side and the attached computer to have an appropriate IP Address, Subnet Mask, Default Gateway and DNS addresses assigned to the network adapter.
Based solely on the title you should understand the following the belief here is that the PS3 is missing DNS address(es).
DNS address(es) are IP address(es) for servers that convert names like www.fixya.com into IP addresses to send messages to normally.
Your ISP generally assigns DNS addresses for your use.
How do DNS addresses get into the computer's network adapter configuration where they are needed? There are two ways generally in home networks someone manually puts them into the computer or someone enters them into the router and via a service called DHCP they get placed in computer's network adapters configured to accept information from the DHCP service on the router.
If the heading of this problem is correct the PS3 appears to be complaining because the DNS address(es) have not been configured into the computer or the router by the user as expected by the PS3's network adapter. I have no PS3 experience however I believe this information may help to resolve your issue.
I hope this helps
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Blitzz Technology BWA711 (B3WL000900) Wireless Router Logo
912 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
fred capra
fred capra
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
