Question about AEG B1180-4 Electric Single Oven
OVEN THE FAN OVEN WORKS BUT NO HEAT COMES OUT
  • ingsy Aug 23, 2008
    I have the same problem. Probably a really basic question, but how do I test the element? Thanks for any replies!
    President:
  • 1,462 Answers
There is a circular element behind the back panel inside the oven - probably open circuit. reasonable cost part and easy to fit.
take the rear panel off the appliance and test the element
Posted on Jul 05, 2008
dniro592006
  • 121 Answers
SOURCE: Main oven doesn't work
it sounds like your gas valve isnt opening
Posted on Jun 12, 2009
  • 197 Answers
SOURCE: Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Posted on Oct 09, 2009
Testimonial: "Thanks, that helps. Will it be easy to fix? can I do it myself? "
barkencoa
  • 3463 Answers
SOURCE: oven not heating up
You need to replace the oven element, as it has probably blown.
It is located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Posted on Jan 18, 2010
Testimonial: "Thanks for your help, I haven't sorted it yet but is given me a place to start. "
  • 40 Answers
SOURCE: fan is working but oven not getting hot
heating element or thermostat
Posted on Apr 07, 2010
  • 196 Answers
SOURCE: My Electrolux EOB5610 fan oven
Sounds like you element is faulty. You can check it by removing the panel in front of the element which is held on by 4 screws then you can visually check it to see if it has blown. If it looks ok then unscrew the element and carefully pull it towards you a couple of inches, this will allow you to pull the 2 wires off, make sure the wires dont fall back inside the machine or you will need to remove the back panel. The use a multimeter on the buzzer or sounder setting and place a probe on each of the pins on the element and if it doesn't buzz or sound then the element is faulty. Make sure you have the electric switched off at all times. Hope this helps
Posted on Feb 23, 2011
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
Fan oven stopped heating
Is the fan working in the oven if not then check if the clock needs resetting.If the fan is working then it is more likely that the ring element around the fan has failed.Check also if the thermostat light comes on,this is an indication it may be ok.
Hope this helps.
May 25, 2010 | Ovens
AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Feb 05, 2010 | AEG Ovens
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Bottom fan electric oven not heating. fan coming on, light coming on, JUST NOT HEATING UP
If fan is working o/k, then you need to fit a new oven element, located at rear of oven behind a removeable cover.
Please rate my solution.
Thanks.
Nov 18, 2009 | Ovens
Top oven on uy46 working, bottom oven light coming on but no heat coming in??
If the fan is working o/k, then you need to replace the oven element, located behind cover at rear of oven compartment, very straightforward repair to do.
Thanks.
Nov 07, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Oven not heating up but fan and light on
oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
AEG B1180-4 Electric Single Oven Logo
88 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De GO PATS
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
