Question about GPS
Garmin GPS Nuvi 200w
Accidently deleted all info when trying to remove duplicate download
I did the same thing, copy all files deleted from other unit and it will work, the conect with Garmin.com and download the map
Posted on Mar 26, 2009
Www garmin com mapupdates free
sorry but only GARMIN can assist you . and you might have to send it to them
Nov 10, 2017 | Garmin nuvi 200W GPS Receiver
Tip
Nuvi 255W Delete Phone Numbers
Garmin Nuvi 255W Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 255W, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 255W.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 255W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 255W WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 265WT Delete Phone Numbers
Garmin Nuvi 265WT Delete Phone Numbers
Would you like to erase the phonebook entries on your Garmin Nuvi 265WT, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 265WT.
Follow these three steps to take to get your Nuvi 265WT running like new:
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Change Nuvi 265WT Home Phone Number here.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 23, 2010 | Garmin n?vi 265WT Car GPS Receiver
Deleted maps...
You can put the sd card into a pc or laptop and try to undelete them. If you are lucky the files are still there but just marked as erased.
You can try to use the update function on Garmin (you need to connect your nui via the usb cable to do this) and it may allow you to get them for free.
Other than those I can't think of anyway that won't take a chunk out of your wallet.
Mar 31, 2010 | Garmin nuvi 200W GPS Receiver
HELP!!!
I can help you update your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Sep 06, 2009 | Garmin nuvi 200W GPS Receiver
Tip
Download Nuvi 200W Manual Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Have you lost your Users Manual or the Quickstart Guide for your Garmin Nuvi 200 or 200W GPS?
Would you like a digital copy of the Owners Manuals for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
Download Garmin WebUpdater here.
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin 265wt. How do you delete duplicate # fm phonebook?
I can help you with the phone numbers on your Garmin Nuvi 265WT.
I hope that helps.
Erase Nuvi 265WT Phone Numbers here.
Feb 10, 2009 | Garmin nuvi 265 Car GPS Receiver
Map was deleted by mistake from nuvi 200W garmin GPS
Connect your Garmin to the computer. Go to http://www8.garmin.com/support/download.jsp then click on mapping updates
Aug 31, 2008 | Garmin nuvi 200W GPS
Deleted voice
Hello Sallilou,
If you deleted the voice files without backing them up you can try running the Garmin WebUpdater software. This program updates the operating software for your GPS and can be used to update maps and other files. It may be possible to reinstall the voice files using WebUpdater. (To download the WebUpdater software go here.)
Some of the Garmin products do have voice files available for download via the Garmin website. (Namely the Quest product.) However the Nuvi 200W does not appear to have such files immediately available for download.
If you aren't able to update the voice files this way I would suggest you give Garmin a call directly.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 13, 2008 | Garmin nuvi 200W GPS
GPS Logo
114 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
