Question about Refrigerators
Ignis fridge isn't cold enough, and seems unable to maintain a constant temperature. I bought a fridge thermometer to get some accurate data: fridge is typically between 9 - 15 degress c. Generally, a good slam of the door kicks the compressor into action, but otherwise the control mechanism doesn't seem to want to react to higher temperatures. Had an engineer out who pointed his infra-red probe at the fridge, waffled for a bit, and said that sometimes the fridge would be at that temperatures as part of the normal fridge processes. Problem is, the fridge is always at those temperatures (adjusting setting only helps slighly). Any ideas?
  • vintner70 Jul 05, 2008
    Hi chris,
    Could you possibly repost? I only seem to have half of your comment.
    Thanks.
    Brigadier General:
  • Refrigerators Master
  • 3,614 Answers
Check the thermostat settings... it is better to clean and defrost the fridge to meet again the desired freeze... let me know if you have defrost the unit and already clean the unit....
thanks
Posted on Jul 05, 2008
    Master:
  • 726 Answers
The compressor is acting weird because the fridge might need regasing if the tempreture
uness the fridge controls for the tempreture nside the fridge are buggered and the thermostat
Fridge now constantly CYCLES ON AND OFF for 10 to 15 minutes
Perhaps calling in a refrigerator repair man so he can check the freon as that is what causes them to run alot more than normal
Jun 03, 2016 | Westinghouse Refrigerators
ENGEL STILL GETS COLD BUT RUNS VERY HOT AND USES MORE POWER
FRIDGE COILS SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
Feb 27, 2015 | Engel MT-35F-U1 34 Qt Portable...
The fridge & freezer has started to get warm it was 8deg above the recomended temperature & then the light starts to flash,we have cleaned all around it,taken food away from the outlets in the...
it can be a defective thermistor,a defective cold control or compressors short cycling(not running long enough) or the evaporatorin the freezer is frozen up and cant keep temps constant
Aug 03, 2011 | Refrigerators
KITCHEN AID REFRIGERATOR PROBLEM We bought a used Kitchen Aid fridge YKSRS22Q (1993), the ice maker is not working but water does work. What should we check to see why the ice maker doesn't work?
Ice makers work off of temperature. If it's not cold enough in the freezer it won't work. Check the temperature with a thermometer, it should be 0 to +10F
Jan 29, 2011 | Refrigerators
My refridgerator freezes the milk, How do i stop it from doing that? The temperature setting is in the normal range and the condensor coil is clean.
There are two setting on a fridge. One that sets the temp of the freezer and one that adjusts the temp of the fridge part. The fridge setting just adjusts the opening between the freezer and the fridge. So the fridge gets it's cool by stealing a little from the freezer. i'd get a fridge thermometer and set it it the fridge and see what the temp really is. The knobs in the fridge may not be accurate. Set the fridge and then move the thermometer over to the freezer and set that. Move back and forth until you get what you want. Usually the lower part of the fridge is a little colder then the top. However if you use the fridge a lot then every time you open the door the cold falls out and the fan will come on and start taking cold from the freezer. Another very cold spot is next to the vent where the cold air comes out from the freezer. Usually up top near the ice maker.
Sep 22, 2010 | Samsung RB215LASH
The thermometer that reads the outside temperature
its not in the engine area, its nearer toward the bumber area, and replace the sensor
Mar 07, 2010 | Suzuki XL7 Cars & Trucks
KTL15V20 fridge not maintaining cold temperature
first buy a freezer thermometer and place in centre drawer on top of food check after 24 hours to confirm 0f/ or -18c/22c sound like you dont have a problem..(air temp in freezer is sometimes warmer than food. this is what keeps the ice off the food/packaging and off the interior of the freezer.
Feb 14, 2010 | Refrigerators
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Oct 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator in garage
Yes it is very possible that exactly what you are describing can be happening. Also try a thermometer frozen in a cup of water to get more accurate temps. Also 33 in the fridge is very normal for the cold control set on max and the heater installed. Let me know the temps in the frz with the thermometer sensing product temp not air temp which fluctuates often.
Dec 22, 2007 | Frigidaire FRT21P5A Top Freezer...
Refrigerators Logo
645 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
