Question about Zenith DVC2550 Multi-disc DVD Player
Disc error always.
It started infrequently with Disc not supported and now unable to get any disc to be recognized.
Is it fixable with a repair manual and Tech experience or does it need equipment only available at a repair shop?
  • Ron Huckstep Jul 18, 2008
    I've run a optical cleaner disc with no effect. will try the liquid cleaner process next as have the tech manual downloaded.
    Thanks. Ron.
    Genius:
  • 1,139 Answers
Hello rdhuckstep,
The problem you are having may be due to dirty optics. First I would suggest getting a DVD optical head cleaning disk try that first. Then use a manual cleaning method using liquid optical head cleaning solution with the chamois head cleaner strips (This will require the tech manual/schematic to show you how to remove the various pieces of the carriage assembly. If this does not work you may have a faulty pickup laser or pickup photo-transistor. In which case you will need to check the optical power with an optical power meter (if you have one), use the instructions that come with the meter and in the technical manual to do this testing. If you do not feel comfortable doing this steps, please take the unit to a qualified TV repair shop.
I hope this helps
Thank you,
Shuttle83
Posted on Jul 05, 2008
Wii disc read error
"Unable to Read the Disc" Error, or Disc Not Recognized (Will Not Play Game Discs) Situation:
  • The Wii console will not play game discs (disc is not recognized)
  • System displays either error message "Unable to read disc" or "Disc could not be read"
Important!
  • If this problem happens very infrequently, it is normal and does not indicate a problem. A Wii Lens Cleaning Kit can be purchased to help keep the lens clean and prevent the situation from worsening over time.
  • Wii Game Discs are region locked, and can only be played on hardware from the same country where the game was released. (A European game cannot be played on a North American system, for example.)
What To Do:
  • The Wii console is only compatible with Wii and GameCube discs. It is not compatible with DVDs or discs made for other home consoles. Verify that the disc you are inserting is compatible with the Wii system.
  • An error message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
  • Verify that the console is placed correctly.
    • If the Wii console is lying flat, the game disc slot should be above all three buttons and the SD Card slot.
    • If the Wii console is standing vertically, the power button should be on the top and the console should be in the stand. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically. (Learn more)
  • Verify that the disc is being inserted properly.
    • If the console is placed horizontally, the disc label will face upwards.
    • If the console is placed vertically, the disc label will face to the right.
  • Check the non-printed side of the game disc for dirt or severe damage (such as scratches or cracks).
    • If the disc is dirty, try cleaning the game disc. (How to)
    • If the disc is damaged or scratched, it will need to be replaced. Please click here for replacement options.
  • If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
  • Make sure only licensed accessories are being used. Unlicensed products do not undergo Nintendo's testing and evaluation process. They may not work at all with our game systems, and they may have compatibility problems with certain games or accessories.
Situation Not Resolved:
How many games does this occur with?
Applies To: One Specific Game
If you are still having issues with the Game Disc after trying the troubleshooting above, it will need to be replaced. Please click here for replacement options.
Apr 17, 2012 | Nintendo Wii Console
Wii Disk Error
Important!
What To Do:
Mar 17, 2012 | Nintendo Wii Console
When I open my JVC GZ-MG27U camcorder, HDD ERROR appeared. Is this fixable? What should I do?
Possible that the hard disc has crashed or has errors within the drive. In most cases the hard disc has to be changed and so you need to get support from JVC for an estimation so as to get an idea of the cost of repair.
Apr 05, 2011 | Cameras
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
Unable to read disc refer to user manual
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Mar 08, 2009 | Nintendo Wii Console
Doesnt read my discs
This happens to me sometimes as well, but usually it's very infrequent, and happens mostly with old original xbox games.
Basically, the xbox is just temporarily confused. Just eject and reinsert the disc and try again. Usually, the second try always worked for me. If that won't work, simply reboot the xbox with the disc in the drive. Now try to run the game.
Let us know if this works.
Ryan
Dec 31, 2008 | Microsoft Xbox 360 Console
Not recognizing mini dvdrw
DVD-R discs can be used with no preparation, but a DVD-RW must be initialised before it can be used for the first time.
You may also have to initialise a DVD-RW if you get the message "UNABLE TO RECOGNIZE THE RECORDING MODE OF THE DISC" .
Also, make sure you always use DVD "minus" format discs - the DC210 will not work with any DVD "plus" format discs.
When you initialise the disc you will be asked to chose between Video mode and VR mode. Most DVD players will play a Video mode disc, but a VR mode disc can be edited with the camcorder. My preference is Video mode - I can then play on a DVD player and edit on a PC.
Don't forget to rate this solution once you've tried it !
Apr 18, 2008 | Canon DC210 DVD Camcorder
Toshiba dvd rom sd r6012 isn't reading the DVDs
Try some factory CD and DVDs and just try to get them to open in Windows (not play in a media player program). If you get errors on every disc you try, it may be your CD/DVD hardware packing in.
If it reads some CDs or DVDs and not others, particularly media discs, you may be having software driver problems, otherwise, it is likely hardware.
Try inserting the disc and spinning it up while resting the laptop on its side, or even upside down. If it reads sideways or upside down, the CD/DVD reader hardware has gone and cannot probably be prepared (this is a symptom of physical controller failure and is ot fixable by normal means).
Good luck...
Nov 12, 2007 | Sony VAIO GRZ660 Notebook
Wont read discs
If it only does this for this one game, you may have a defective game disc, it happens. Often, if you have just recently purchased it, you can return it to the store and tell them that it was defective and get a new one. If not, you can always try cleaning it though I doubt that's the problem.
nintendo.com says "If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options."
Oct 01, 2007 | Nintendo Wii Console
Zenith DVC2550 Multi-disc DVD Player Logo
129 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
