Question about HP Pavilion dv1000 Notebook
Weird power issue
I am completely stumped. I have an HP Pavilion dv1000 (dv1133wm) which only turns on once I reseat the battery. I can push the power button all day and it will not turn on (no response whatsoever) but as soon as I reseat that battery it turns on fine. Also when I RESTART it just completely powers down as if I SHUTDOWN. I have cleaned all connections, reseated all of my hardware, and flashed the BIOS with the latest version (which HP said to do) and I am still having the same issue.
  • FamousTim Jul 15, 2008
    I have the same issue when the battery is removed. Thanks though :)
  • 45 Answers
Have you tried removing the battery and then turning the laptop on? If this works then you have a battery issue rather than a battery terminal problem (which is the only other issue I can  think of that would survive a BIOS reset.
Posted on Jul 08, 2008
All the lights turn on on the hp pavilion dv1000, but the screen remains black. Almost as if there was no power going to the screen. I have tried reseating the RAM and the HD. Problem still remains. ...
Hook a external monitor to the video output on the back of the laptop, if okay! there is a LCD problem with the laptop screen, causes! bad inverter board, or back light. If both show black! causes are Video Graphics Card that is part of the motherboard.
Jan 10, 2011 | HP Pavilion dv1000 Notebook
I have an hp pavillion dv1000 it works fine but the screen is very faint i can barely make out the icons... i tried pushing fn f7 which is supposed to make it brighter and nothing happened... any...
the backlight may be going or has gone out, is it plugged in or running on batteries? when plugged in it should be bright with a battery is usually dies down so as not to use alot of energy.
If that does not help, try function key and making it darker, I know that sounds weird but sometimes it gets stuck in a weird loop, My dell laptop does it all the time.
Sep 10, 2010 | HP Pavilion dv1000 Notebook
It wont turn on whether its plugged in or not....
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook.
Step 2: Remove and reseat memory modules
You can refer the service manual provided below for information to remove and reseat the memory modules.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Refer page no: 121, 122 & 123
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
However, if the issue still persists, then it is clear that the issue is due to internal hardware malfunction of the notebook and requires a detailed onsite diagnosis by a service technician. At this point, I would recommend you to take the notebook to a nearest Computer Service Center to get it repaired/serviced. I hope the information provided would be helpful.
May 14, 2010 | HP Pavilion dv1000 Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My Dell dv1000 has completely died
You are listing this unit as a HP and stating it is a dell.???
Nov 06, 2009 | HP Pavilion dv1000 Notebook
Hp dv1000 - lcd is black(you can see image with flashlight & external monitor works) I've checked all conections & replaced the inverter. what's weird is hat every once in a while the lcd comes on...
back light on the LCD is not working,
LCD needs to be replaced...
The Price at hp is around $398+taxes,which will give you 90 days hardware warranty..
Oct 11, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Internal Mic Issue...
Go to check on support manuals on HP website.
Sep 23, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 PC Notebook Audio Problem
There are two different audio cards shipped with Pavilion DV1000 series Notebooks.
If your Notebooks belong to DV1600 series, your Notebook should have been shipped with Conexant High Definition Audio card.
This can be one of the reason why you are unable to install the Conexant AC Link audio drivers in your Notebooks.
You need to install Microsoft UAA Drivers first before installing the Conexant High Definition Audio Drivers in the Notebook.
Download the Microsoft Universal Audio Architecture(UAA) Drivers for your Notebook from the HP link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Please save the file in the Notebook and double click it after the download completes to install the drivers. Restart the Computer once the installation of the Microsoft UAA Drivers is completed.
Now download the Conexant High Definition audio drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32864.exe
Save the file and double click on it once it is saved to install the Drivers.
This should solve the issue with audio in your Notebooks.
Hope this helps...
Aug 24, 2008 | HP Pavilion dv1000 Notebook
Have you followed the recommendations on HP SITE
If the screen is blank they suggest disconnect the power, battery, and reset the memory modules.
May 25, 2008 | HP Pavilion dv1000 Notebook
Pullin my hair out
  1. remove power
  2. remove battery
  3. remove memory modules
  4. reseat memory
  5. replace battery
  6. plug back in.
May 21, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
