Question about Dishwashers
Hotpoint Aquarius DWF50 Dishwasher, cycle not starting getting flashing ECO/Fast lights, any ideas?
Hotpoint dwf50 will not start, the fast wash and prewash buttons are flashing together.
Posted on Sep 25, 2008
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
I have a hotpoint aquarius sdw60 with the eco 45 light flashing fast and will not reset I have tried turning off the power I have stripped the pump this was clear. then reinstalled it but it is still same
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Jul 13, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Failed to complete cycle.
Probably blockage in pump or sump hose from drum to pump.
Remove and clean.
Nov 22, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint dish washer aquarius
I had the same problem with my Hotpoint Aquarius the eco and fast light flashing, it would go through the pre wash cycle and stop.
I cleaned the filters etc; and it still didn’t work.
I turned the machine off and unplugged it at the mains,
I drained all the water, turned the machine on the side and took the bottom off, I removed the drain pump off the bottom (this was held on with a single screw after taking the screw out slightly turn it to one side as its like a bayonet fit on a light bulb also remove the wire connection and a rubber drain pipe)
Once the pump was removed I could clearly see the impellor it was very tight and I couldn’t spin it after a closer examination I could see a foreign object jamming it I removed this with a pair of tweezers, replaced the pump and put it all back together and it now works perfectly.
I hope this can be of some help.
Peter.
Aug 26, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Jun 16, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint dishwasher dwf50
i had the same problem and like an idiot paid for hotpoint to come out and all the guy done was tip the dishwasher backwards to empty the water(which he didn't clean) and tell me that im using to much rinse aid and salt coz we use 4 in1 tabs hope this helps smiley
Mar 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
FDW60 Fast and Eco Lights
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Mar 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
1,775 people viewed this question
Top Dishwashers Experts
