Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Blinkink light I also have a 65513 and after a power outage my tv will not come back on, the green light blinks constantly. Have plugged/unplugged set repeatedly, have done the hard reset repeatedly, no luck. Please send me the instructions also to jcarnell@hiwaay.net. Thank you, John
  • 927 Answers
Good Day, jcarnell;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Posted on Jul 18, 2008
Tv will not turn on green light blinking
Unplug the tv, and plug it back in. Wait a minute and it should come up.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
What else the blinking green light
Please research this more before asking a question! There are 4 caps in the DM module that need to be changed. It DOES require some technical skills and soldering experience. If you still have not found the answer to this problem, let me know
Sep 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Aug 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513
if you changed the energy mode from standard to low that is normal, anytime you turn the set on it will do the same,
plug set green light will blink one minute.
turn it on it will blink onother minute and then turn on(make sure that you dont keep pressing power key) once on you can change your settings again.
hdtvman.
Apr 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
