My washer fills with water but after that nothing it just hums
  • 177 Answers
You may have motor issues, Call a service tech
Posted on Jul 07, 2008
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Just moved front load beaumark washer into a new house, and it won't fill with water. the display lights up and you can here washer trying to fill (humming noice). All display lights come on and it...
It sounds like your water inlet valve is either not getting a signal to let water in from your control board or the water inlet valve is defective. Since you are hearing a humming noise, I would say that the water inlet valve is defective or has been damaged in transit.
Jun 18, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer stop before completely filled with water.
beko washing machine when turn it on it trips
Dec 12, 2009 | Kenmore Washing Machines
the bearings are bad if it is an older unit you are better off buying a new one
Oct 04, 2009 | Washing Machines
My washer won't fill with cold water...only the hot works.
Cold water solenoid on the water mixer valve is likely shot.
Change the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Fill with water - Stopped in the wash cycle - Blew Breaker
please put unit in a out by its self...recontact if still problem
Dec 15, 2008 | Kenmore 15864/15862 Top Load Washer
Washer won't fill with hot water
If you hear a humming, the coil on the water valve is probably OK. On warm, you are getting cold fill only. (hot + cold = warm) Take the hot water supply hose off the machine and look inside where the hose attached to the washer. There should be a screen inside. Remove it and clean it out. Also, check both ends of the supply hose, as sometimes you will find a screened washer in there too.
Oct 26, 2008 | GE WBSE2090A Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
