My cannon mp370 keep coming up with waste ink near full
    Scholar:
  • 49 Answers
I think this one will help you
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Posted on Jul 05, 2008
Cannon mp 370 waste tank nearly full How do you clear this
This is a pair of sponge that absorbs excess ink after you print a page. You can get a service kit from Canon or just pull them out and rinse clean. Unfortunately they are 12x5cm and 20x5cm felt pieces at the plastic base of the printer (probably one on each side) and very difficult to reach. If you do get them out and rinsed clean, you can reset the counter for the waste ink tank.
The procedure:
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
I hope this helps.
(ink jet printers are really designed with the expectation that they will be replaced when this error occurs.)
Mar 30, 2010 | Canon MultiPASS MP370 All-In-One InkJet...
Printer warns waste ink near full. Cannon
Hi
The waste ink are in the inside of your printer you need to get at it to clean out, but after this you got to reset it or it will still not work, I not know about your printer I have only looked it up for you. It may be screwed down inside so you need to open all up or get a shop to de it for you.
I not find your model printer on the internet but I found one and it same type of printer as yours MP210 but a different number it canon MP190 and it have a reset waste ink for it you can try it may work for you, try resetting it first before you try clean it, if this not work you will have to find the right reset for it.
Ok here it is.
You have to do so:
1) Enter service mode by pressing: MENU, COPY, SCAN, COPY, COPY
2) Select TEST MODE
3) Select (8) PRINTER TEST in TEST MODE
4) Select (3) (eeprom clear)
5) Select (0) (ink count)
6) Press the SET key
7) Press the STOP/RESET key, then press power key to power off
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Feb 03, 2010 | Office Equipment & Supplies
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
What does Waste Ink nearly full mean? Canon MP370
If you peel enough apples, and throw the "waste" apple-peel into the basket, eventually the basket gets nearly full, and must be emptied.
Similarly, if you print enough pages, some of the ink becomes "waste",
and that "waste-ink" goes into a small sponge-and-bucket apparatus.
So, take the printer to a qualified technician, and get the printer serviced.
Nov 23, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Waste ink nearly full LCD ERRoR on Cannon multipass F60 printer
HiHello try ths
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
6) Press the [OK] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Oct 17, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Wast ink
Your MP780 printer has decided you have too much ink from the cleaning cycles in the absorbent pad inside the printer. Go to www.fixyour ownprinter.com and put "MP780 waste ink" into the search function. Follow the leads to find out how to clean the waste ink out and more important to find the code to reset the printer to get rid of the waste ink message.
Apr 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error waste ink tank near full
This page gave me a solution, try it.
Let me know if worked for you as for me scoring this solution. Thanks
Jan 30, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
CANNON MP370 WASTE INK TANK NEARLY FULL
what does this mean and how can I solve this please
Oct 02, 2008 | Office Equipment & Supplies
Ink cartridge
The real problem is that the waste ink tank is nearly full
Correct code procedure for resetting the Canon MP370
Reset Waste Ink
By pressing the black button
with the star (in a
head ?) above it, followed by
scan, copy, scan
2) Select TEST MODE (press right
arrow button 13 times).
4) It'll now say "- 8-2 +" press
the right arrow key once
to get "- 8-3 +" Hit ok.
6) Press the ok key.
7) It should return to showing
the "8:
Printer Test - 8-3 +"
8) Press the [Stop/Reset]key -
black key with triangle and
circle on it –
key.
Good Luck and don't blame me if it
goes wrong !!!!
Now you can print again, but it has not solved your full ink-tank, that has to be solved in future.
Theo
Jul 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
135 people viewed this question
jasbo
jasbo
