Question about Indesit Dishwashers
A10 ERROR CODE ON ALL PROGRAMS ON INDESIT IDE1000 DISHWASHER
IFIXALL
  • 868 Answers
SOURCE: indesit IDE 1005 error code
Replace the control board
Posted on May 22, 2008
  • 157 Answers
SOURCE: error code A10 for hotpoint FDW70G
heater
Posted on Dec 19, 2008
  • 69 Answers
SOURCE: fault code A10 on indesit dishwasher
A10 fault indicates heater open circuit fault. Problem either heating element, or control board. Test element for correct continuity and resistence, if OK, replace controller
Posted on Aug 08, 2009
SOURCE: indesit dishwasher error codes
why does the spray arm fall off?
Posted on Sep 07, 2010
  • 70 Answers
SOURCE: my dishwasher is showing error
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Posted on Jun 12, 2011
A10 code Indesit Dishwasher DSG573
A10 is a heater fault check heater or look for poor connection on module normally the pink or blue wire
Jan 24, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Fdd914 dishwasher error code A10 appears and its not in the booklet
Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
My dishwasher is showing error code a10 model ide 1005
Jun 12, 2011 | Dishwashers
Fault code A10 on indesit dishwasher, how do I fix it?
Aug 07, 2009 | Indesit Dishwashers
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit IDE 1005 error code
May 22, 2008 | Dishwashers
IDL 700
A10 2 & 4 Heating element Open circuit heater
info from idl service manuall
Feb 29, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Hotpoint Aquarius+ FDW70 Error Codes
i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
May 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
79 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
