HP Photosmart C6280 Printer Logo
Posted on Dec 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do send image from scanner to computer - HP Photosmart C6280 Printer
mukhtar21 shaikh
Level 3:
President:
  • HP Master 2,022 Answers
  • Posted on Dec 24, 2010
mukhtar21 shaikh
HP Master
Level 3:
President:
Answers
2022
Questions
Helped
669010
Points
5817
You need to install the application software .just install the cd which come along with the scanner it contains the driver as well as the scanning software just install it .then you will be able to use the scanner button .
Have a nice day and do not forget to rate please...!
Could you help me to operate the scanner., so that I can send docs,
make sure your scanner is working properly and the software has been already installed to the server or computer to access the scanner. this steps can help you to operate the scanner.1. connect the scanner to your PC, mostly scanner now is using USB cable 2. and then turn ON your scanner, place your material to be scanned like you were using photo copier 3.press the scan button to acquire the image 4. then preview the scan, the scanner software should display a preview on your computer screen 5. and now select the scan area in the scanner software 6.next set other options for example set the the color or the resolution of the document 7. then scan the image and save it into your disk make as your new folder. after you save you can now send this document.
HOW TO USE THE SCANNER FEATURE ON THE HP PCS 950
You can start a scan from your computer or from your HP PSC. 1 Load your original.
2 Press Scanner, then press PC Save, if not already lit. This saves the scan to your computer.
3 Press Black or Color. For Windows, a scan of the original appears in the HP Image Viewer. For Macintosh, a scan of the original appears in the HP Workplace. In the HP Image Viewer, you can edit the scanned image. When you are done viewing the image, click Accept.
The HP PSC does a final scan of the original and sends the image to the HP Photo View Center in Windows. In the HP Photo View Center, you can:
- edit images, including adding text
- creative printing
- create and print photo albums
- send to fax, e-mail, web page, or other programs.
additional information can be found on this website:
http://www.retrevo.com/support/HP-950-Multifunction-Printers-manual/id/260dj582/t/2/
I have never used a scanner please explain
If you are just installing the scanner, follow the setup instructions that came with it, and make sure the software gets installed. If it is already installed, then there should be a program in the computer that can start the scanner and get the image of whatever is on the scanner. Look where the scanner programs are at(usually this is a folder on the start menu). Also, there may be a scan button on the scanner itself. Pushing this button will start a scan and send the image to the computer.(the scanner program should start)
1helpful
Will not Scan. Gets message..
Is it installed in windows as a scanner? Dont use scan button on machine try using scanners or document imaging software that needs to be in place on your computer, ie Document imaging in office or scanners and camera in windows, one sends scan signal from the PC, can use the scan button on scanner only when configued to do such. Scanner has software as does the printer both can found at HP web
Can i share scanner across multiple computers?
Some network scanners have the ability to scan to PC's. I have the Brother MFC-465CN all-in-one ethernet network printer. This scanner lets me press scan and decide which PC to send the scanned image to.
If it is a USB scanner then I don't think this is possible.
Why I am unable to send scanned messages by email succussfully, they are not readable by the recipient. I can scan and copy and send successfully, as an email attachment, but the recipient says the print...
hi, do check ur scanner settings. It is advicable to save the scaned image as a JPEG and then u can easily mail it. Do set the are the scanner is goin to scan perfectly. and see to u do not interupt he scan before u get the image on ur computer. If the problem persists do post again.
4helpful
2answers
Have no manual; need help using scanner and fax
Here is the link given to the user manual. that contains the optimum solution to your problem and maximum guidance.
http://www.devicemanuals.com/guide/All-in-One%20Products/HP/HP-PSC-950-All-in-One-Owners-Manual-==TVRFME56VTI=.html
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=34579
Driver yakumo for window vista
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/Yakumo-Mega-Image-XL.shtml
GO TO THIS LINK AND DOWNLOAD THE DRIVERS FOR WINDOWS VISTA
ENJOY
RAHUL
Scanner
Try scanning from the image software you are using, not from the front panel buttons. Go to the TWAIN options and make sure your scanner is selected, then go to Acquire and the scanner software will start. Scan from there without using the scanner front panel.
Email
The Scanner software may have the opportunity to do this.
Otherwise send it as an attachment in a regular E-mail
When sending images by e-mail make sure they are of size that the recipient's computer can deal with.
One way to do this is the down load and install ShrinkPic from www.onthegosoft.com- This automatically resizes the image acceptable to E-mail
k24674
Grand Canyon Tech
Grand Canyon Tech
