No channels can be detected have tried 2 Daewoo DS608P boxes connected to same telly but same thing happens. Signal strength seems fine boxes have been working fine for years.
  • Anonymous Aug 01, 2008
    Daewoo DS608P - Working fine then as of 31st July 2008, no channels found. Location Borehamwood. There appears to be no solution either as it seems that this unit is suddenly uncompatible due to signal changes.
Read this http://www.dailyrecord.co.uk/news/scottish-news/2008/07/05/exclusive-thousands-of-scots-face-tv-blackout-after-freeview-signal-change-86908-20632202/
Posted on Jul 11, 2008
  • alashstare Jul 11, 2008
    http://www.dailyrecord.co.uk/news/scotti...
I am the same. Not a sausage from my same model Daewoo freeview box today. Scans and re-scans and not a single channel to be detected.
Rob
Posted on Jul 05, 2008
I have a foxstat -HDR humax box and I am getting no or bad signal on the TV downstairs. I can get some channels but not all.
I suspect that the box upstairs is a Freesat box; a Freeview box requires a feed from an aerial, not a dish.
The problem you are seeing may be caused by water in the cables, if they are not sealed at the LNB. The LNB may be failing, but dish misalignment is more likely.
As there is an unused output on the LNB, try swapping one of the feeds with a poor signal to it.
Jul 27, 2015 | Humax Televison & Video
I have an old wannadoo live box on orange worked fine until I moved home. Orange have confirmed that internet has now been set up at my new address and I kept my old phone number. The LAN into my...
i assume you have DSL connection through phone line . double check the cables see if they are connected properly betwee the modem and router etc ..if its all connected then reset your router by pressing littile tiny button at the back of Router and apply new WPA2 password and try connect .
May 12, 2011 | Computers & Internet
Pixelation of TV channels via Settop box
Pixelation is caused by poor signal strength. Check the signal strength in the setup section. Unfortunately some boxes and TVs don't handle poor signal as well as others. It might be worthwhile trying a signal amplifier
Jun 12, 2010 | Televison & Video
Signal strength bad between PS3 & D-LINK DIR-655 Wireless Router
Most likely it is the antenna for the router. Try changing the position or location of the router. The slightest twist or tilt of the router will affect the reception. A little bit of messing with it may improve your signal. Obviously the closer you can get it to your ps3 the better.
Sep 10, 2009 | D-Link Xtreme N DIR-655 Wireless Router
When i first purchased the router, sgnal strength was fine. now in the last 2 weeks, i get only 40% signal strength at my downstairs location. when i'm close to the router, strength is 90-100%. what...
It seems that the router is getting interfrence on the wireless channel it is using. Please change the wireless channel on the router and check if that helps.
Jun 13, 2009 | NetGear RangeMax WPN824 Router
No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Nov 24, 2008 | Televison & Video
Starview 2 the box- no signal
hi you never said if you had the power up box for the aerial and if your aerial is facing the correct way make sure you have your connections are right get that checked before you look further you have a few options to do before you delete everything check your signal strength answer these first
Nov 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
Daewoo ds608p cka not picking up a signal have scanned several times but not finding any channels?
I have not resolved the problem i am waiting for you to come back to me! I was given the option of signing up for the premium plan which i declined so presumably i will not get the free advice offered?
Aug 29, 2008 | Televison & Video
I have a Daewoo DS608P Freeview box which will not detect any chennels. The pre=scan and scan appear normal, but nothing is detected. The TV, which has no Scart socket, works fine on analogue, and I have...
Sorry to be the bringer of bad news but the transmission mode in the uk is changing & that is why your box will not pick up any channels have a look on http://www.freeview.co.uk/help/faq/id104963 I'm affraid your box is finnished.
Jul 25, 2008 | Televison & Video
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
