Question about Dryers
Hotpoint TDL 11P
Thank you for your assistance re diagram 0 very useful - however I would like to know whether I access the drive belt from front, sides or rear 0 it looks like I need to go from the front
Thank you in anticipation
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I attempted to locate an answer to resolve the issue for you, but your model number came back as invalid. However, any Hotpoint that I have ever serviced was all done through the front.
The link below shows disassembly from the front, but without a proper model no. this is only a guess. Once you access the site, you can navigate through numerous pages of instructions to aid you in servicing the dryer
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
http://www.repairclinic.com/0100_15.asp
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
Hotpoint TDL 14 Dryer. Motor is working but drum not turning?
Remove the top cover and check to see if the belt is o/k, or could be collapsed rear bearing, remove the rear cover and check the drum bearing.
Nov 22, 2010 | Hotpoint Dryers
Hotpoint TDL 31. Seal between drum and door seems worn
Yes espares.co.uk will have parts and advice, sounds like you could have bearing problems...if its noisy on spin....
Apr 08, 2010 | Dryers
I need to replace the drive belt on my 98 Ford Escort ZX2 manual transmission and need a diagram and to know where the tensioner is located. It is a single belt.
There are 3 possbile diagrams, depending on whether it's equipped with AC and engine type. The 3 are listed below. Thank you for using Fixya and please remember to return to rate this answer.
Greg
98 Escort Drive Belt Air #1
98 Escort Drive Belt Air #2
98 Escort Drive Belt no Air
Dec 20, 2009 | 1998 Ford Escort
Older model dryer--drum will no longer spin. Need
The model number you provided is for a White Westinghouse. In order the access the internal cabinet to view the drum, you will need to lift the top panel. This is accomplished by inserting a putty knife along the front seam where the top meets the front of the dryer. About 2 inches in from each side is a small retaining clip. Push in with the putty knife and the top should pop free and lift up. The belt should be visible around the drum if it still intact. If the belt is loose, or missing, it has probably broken.
NOTE: The only way a belt will come off the drum while enclosed in the cabinet is if it breaks.
CAUTION: Make sure you UNPLUG the dryer before servicing. Dangerous voltage is still present inside the dryer even with it turned off.
To access the drum to replace the belt, you will need to remove the front panel. Remove the lint screen and lint screen cover in the door, first. Then, remove any screws holding the panel in place. The belt can be installed with the drum in place. Simply loop it around the drum first, then feed the remaining portion of the belt behind the blower fan housing and loop it on to the drive motor pulley and belt tensioner.
The part number for a replacement belt (if required) is 134503600. You can purchase a new one at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Prices vary between these sites, so shop around for the best deal. The first three sites also offer very helpful exploded view parts diagrams you can use as reference. Repairclinic.com will have diagrams to show up how to properly route the dryer belt. Just click on the "Repair Help" link, followed by the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram G under Westinghouse.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: If the belt isn't the problem, please let me know.
Oct 10, 2009 | Dryers
Hotpoint 17450 dryer belt diagram
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page look for the "Dryer Belt Diagrams" link under Special Features. Depending on the when your dryer was manufactured, you will either use diagrams M, D or L. If you do not know the age of the appliance, it is determined by the serial number. If you need further assistance, please let me know. I hope this helps you.
Jun 11, 2009 | Dryers
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Need to replace drive belt on hotpoint wf430 but to tight to get
Put it on the motor spindle first then feed it onto pulley. It is tricky with such limited access.
Hope this helps &thanks for using Fixya.
Jan 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint TDL 52P tumble dryer stopped working. When switched on just get a high pitched electrical buzz and the drum does not spin
Sounds like a broken drive belt.
R emove top cover and check the belt.
I t should be round the drum, check toi see if it is still tight..
Nov 27, 2008 | Dryers
Hi i am trying to replace the large drive belt on hotpoint 17351 s/no 49440026 please can you show a route diagram thanks gwyn
Go to repairclinic.com and click on the "Repair Help" heading. On the following page is a link for "Dryer Belt Diagrams". Hotpoint will either be drawing M, D, or L. This depends upon the year your dryer was manufactured. I hope this helps you. Let me know if you need further assistance.
Aug 20, 2008 | Hotpoint Dryers
Hotpoint WD71s
The e30 error code relates to motor drive problem. Open the service panel and look for a broken belt and does the motor spins. Let me know with your results if you will need for further assistance. Good luck!
Sep 08, 2007 | Hotpoint Ultima WD72 Front Load...
Dryers Logo
114 people viewed this question
Top Dryers Experts
