Question about HP OfficeJet 4255 All-In-One InkJet Printer
No printout Sir, I give command paper moves comes out no printing takes place,
  • 25 Answers
Did you try to print a test page from the printer from setup button
Posted on Jul 08, 2008
Letter outline printing detail
your copier not set paper size.Paper seize is miss mach so several times print same print
Jul 13, 2012 | Canon imageRUNNER C6800 Copier
Dear Sir, i have buy hp laser jet p1007 printer but it gives no quality. it gives faint print and when i give pdf file print command it give very faint print so what can i do. Thats the faint...
Hello and Welcome to FixYa!
Hmm, faint printout may occur due to so many issues, like paper quality, bad connection, bad/dirty pick-up roller, wrong settings...
To counter all these issues, writing all the text here will be difficult and will decrease the understanding quotient. So I'm attaching a link below, where you will find all the possible solutions with pictorial / graphical representations, I hope you will find it helpful and will definitely come up with some solution.
In Case you are having any issues/questions, do ask me. I'm here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Resolving Print quality issues
Aug 09, 2010 | HP LASERJET P1006 Printer
I am having problem in taking printout from TOSHIBA E STUDIO 166
You are trying to print to paper size that is not installed in the machine. Check what paper is installed in the machine then set your software application default paper size to the same value and then print away!
Sep 10, 2009 | Toshiba e-Studio163 Copier
Printer taking too much time to print
Please perform the steps and check if it improves the printing speed.
1. Click Start or Windows Logo>> Control Panel >> Printers and Faxes or printers
2. In the Printers window, right click on the printer icon and click on Properties.
3. Click on Advanced tab.
4. Under this select the "Print Directly to Printer" option.
5. Click on Apply and OK. Now try printing.
Wish
Aug 01, 2009 | HP Office Equipment & Supplies
It prints offset I try to print something and it starts the page half way. then after a page or two, the colors are all wrong. cxan thsi be fixed
Hello sir , I have installed Datamax I class printer with my pc & now i want to take the printout by using the bartender software.
previously i used zebra printer so i have label format but now
Problem is :
after give the command to datamax printer
print format comming very small not as per define format.
Jul 31, 2009 | Konica Minolta magicolor 2430 DL Laser...
Unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
May 14, 2009 | HP LaserJet 2840 Printer
Sir/ madam printer is not taking printout from computer. Our all technicians could not solve this problem. please suggest me what do do. thanks
hi im josh in phils. may i help you. friend your problem is quiet serious cause if your printer head is damage thats why it will not execute to give the cartridge command to print the paper with ink. i suggest you replace the printer head.good luck
Feb 21, 2009 | HP LaserJet 3050 All-In-One Printer
Estudio 352 is not help to take out printout from computer
Hello sir; When you make copy does it print? if there also no print out you better check the corona wire (charge & discharge) it should take care of you, if still don't work let me know.
Dec 30, 2008 | Toshiba Estudio 200L Copier
Standard top bin full remove paper
Hi there is seems that the machine thinks there is too much paper at the paper printout exit. If there are printouts on the top of the printer remove them and the printer will start printing or the error message will go away. If there is nothing on top of the printer then where the paper comes out after it has printed you will see a black plastic lever type it is more likely to be in the up position without breaking it if it hasn't already been broken move it so it is in the down position it is on a hinge so be careful and it should sit at an angle. Once this has been done the printer will reset the message itself.
Hope this is help you oh if the arm is broken it will need replacing (just the arm)
Thanks J
Jan 12, 2008 | HP LaserJet 2420 Printer
Problem with printing with HP 1022 laser printer
Hi, Laserjet 1022 printe supports printing through the Laserjet 6L drivers and its tested, please select the same USB port for the Laserjet 1022 printer which is selected for the Laserjet 6L printer and then try printing. Ragards, MukeshS
Aug 18, 2006 | HP LaserJet 1020 Printer
HP OfficeJet 4255 All-In-One InkJet Printer Logo
32 people viewed this question
Ben Johnson
