Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70P Fridge freezer. High Freezer temp.
I have checked and cleared the ice behind the panel in the freezer. Then ran the freezer and it appears that freezer matrix is getting cold, but I have not heard or seen the fan operate in the last few days since this alarm has come on. What other things should I check for?
  • 958 Answers
Can you check the resistance of the fan?..or even the voltage going to the fan ( just be carefull ) if there is presence of voltage, then the problem is the fan, if there is none, you have to trace why. if it has a diagram, you an trace it. or the switch could have been open that is why it is not running. push the door switch if it has one and check again for presence of voltage. i hope i was able to help.
Posted on Jul 05, 2008
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
Where is the reset on my refidgerator wont get cold enough kid left it open
May 09, 2012 | Hotpoint-Ariston HSS25GFT Side by Side...
FRIDGE OK FREEZER NOTWORKING RED WARNING LIGHT ON
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 03, 2010 | Hotpoint RFA60 Bottom Freezer Refrigerator
RED TEMP WARNING LIGHT ON MOTOR RUNNING
I'm sorry to have to tell you that this sounds like a very expensive fault to fix!
Either your fridge/freezer has degassed (lost the refridgerant gas) through a small leak in the pipe system behind or inside the freezer compartment, OR the compressor (what you called the motor) has started to fail.
Either way, these are very expensive repair jobs. It's possible to replace the compressor within about an hour, but if your model is out of guarantee, there will be around a £50/60 Call-out charge and the compressor will cost between £75 and £150 depending on the model.
Alternatively, if the fridge/freezer has lost gas, the engineer would have to try to find the leak - this could be IMPOSSIBLE if the leak is within the pipework inside the back of the fridge or above/below the freezer compartment.
I'm sorry to say that it's looking like you may have to part with a lot of money - or say goodbye to the fridge/freezer you have!
Nov 17, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first:
Dec 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint FFA70 Freezer High Temp
sum fans only kick on if cold enough
if the whole evap is frosted up u have a defrost problem
if frost is only partial u need to throw it out cause it either has a bad compressor or freon leak
check your fan by compressor and make sure coil isnt filthy too
Jul 08, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
422 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
