Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
My screen has gone black
Good morning Sir/Madame,
my screen has gone dark when I switch the screen off and back on it say screen is in power save mode press any key or move mouse then it goes black again.
  • doro7 Apr 08, 2009
    Could an erratic software command accessing the screens logicboard cause the issue ? Here all video display (incl stfc) dissappeared all in a sudden.
  • 282 Answers
Try to reseat the vga cable of the monitor,reseat at the back of the computer and on the monitor,if the cable is disconnected,make sure that you can see the power on self test with different colors in it,if you cant see it then your monitor went bad,try to connect another monitor to your computer,see what will happen,try using other cables as well
Posted on Jul 05, 2008
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
Compaq Evo N600c Laptop over 5 years old but has been working fine. About 2 months ago the screen went dark (bad lamp?) so been using an external monitor. Turned it on this morning and it started to boot...
Do you see any lights on the laptop that are on? If you see any lights and only a black screen, then more than likely your video chip on the motherboard has gone out. Some local shops might be able to replace the motherboard it might be cheaper than buying a new laptop. Good luck
Feb 25, 2011 | Compaq Evo N600C PC Notebook
I have a hyundai monitor which keeps switching itself off Displays the computer screen then goes into energy saving mode after a second or so Help!
alastairhaig, Is unit 4 years old? Could be problem with units switch-mode-power-supply if same thing occurs when connected to fully functioning different pc that has all screen saver and power save features disabled. After screen goes "black" do you still see the WIN-desktop screen and icon's if you hold a bright flashlight at different angles about 1 inch from the screen? SEE = power supply in "partial shutdown" mode. NO SEE = smps in "full shutdown" mode. Do some reading in my fixya profile about "black screen of death" repairs. also read FIXYA profiles of "budmrtn" "buddymc" and other fine profiles of technicians here on fixya. You will truly be amazed when you visit YOUTUBE for video clips of owners/technicians who save their cold cathode fluorescent lamp, back-lit lcd monitors from the "trash-heap"!!! After you do your research please return here and rate this response and possibly do additional comment. 12fixlouie
Oct 12, 2010 | Hyundai Electronics Hyundai N91W (Black)...
My monitor has just gone dark pictures now all look under exposed this has only just happened not sure what to do
magazine991, Use your warranty first! It's free! The internal "switch-mode-power-supply" has gone into partial shutdown mode. If you couldn't see the faint image on the screen using flashlight 1 inch from screen then it would be in FULL shutdown mode. You must have very good vision!!! Now all you need to do is get into my fixya profile and read, read, read!! Your monitor's basic design and operating principles are NO DIFFERENT than any other brand of CCFL back-lit LCD unit! Find out all your options on what you can do with your now BLACK but not BLANK monitor. Do not rate this response till you want to break this link. Do make a comment for more info if you still don't know what to do. I'm 12fixlouie Bye for now
Feb 10, 2010 | BenQ FP202W Monitor
My printer does not print full black it comes out light and dark
Hello sir; The ricoh copier have toner save mode if youwant print whole page in black, then you have go to SP mode group 2 looking for "enforce toner adding" you have to executive for couple times otherwise you have not enough toner tocover whole page, enter SP mode you press "clear mode", "107", and then pree and hold "clear/stop" key until SP mode display, then touch SP mode on screen, touch group 2 looking for what you want.
Jun 03, 2009 | Ricoh Office Equipment & Supplies
Black/white/rainbow screen
Sounds like power board issues, if your able test the voltages coming out of it and see if they are correct
Nov 23, 2017 | Insignia 19 in. Widescreen Flat-Panel LCD...
Problem Using stand alone monitor with laptop computer
signal out of range suggests that your laptop is asleep..open the display settings, and disable those, until you get this resolved.
Oct 15, 2008 | Dell Inspiron 8600 Notebook
Problem acer 5052
While your using the windows environment try alt and enter keys similtaeouly should give you the ol dos style.
Sep 29, 2007 | Acer Aspire 5050-3242 Notebook
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
471 people viewed this question
Alun Cox
