I have connected by Samsung HDD?DVD recorder (DVD-HR773/775/777. The remote turns it on and off but it doen't open to put a disc in nor does the menu come up. Should the menu show on our TV? If so how do I get to a video channel? I have a new Sharp TV Thanks
  • Anonymous Jul 12, 2008
    We have the same problem, anyone know how to solve this?
  • 1284 Answers
SOURCE: Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Posted on Feb 23, 2007
  • 1003 Answers
SOURCE: go video DVD/VCR recorder Model number VR-3845
First make sure you are using a quality disc like:
memorex Brand dvd-r.
Posted on Jan 14, 2008
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
  • 487 Answers
SOURCE: hdd recorder / recording & watching cable channels
yeah actually that is kinda simple. Like the old vcr recorders you can just put a splitter between the cable (input) and your dvd hdd and your tv.
that is an easy 3 dollar solution
Posted on Apr 30, 2008
SOURCE: Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Hey New firmware available for this "Timer issue" from Samsung and it works for me.
New firmware version - 080610.
Just ring Samsung and find out. They can advise nearest service cnter to do this.
Posted on Feb 13, 2009
How to enter disc menu for finalizing dvd-r on philips dvdr3330H
The Disc Settings menu is accessed from the Disc Index Picture screen (so it's not as easily accessed as on other brands of DVD recorders). When you first put a recorded disc in the device, you'll see this index screen. At this point you need to press the UP arrow on the remote repeatedly until the disc content menu appears. This is a screen with the disc name, amount of recording time used and the date of the first recording. Then press the Right arrow button to get to the Disc Settings menu. Use the Down Arrow to reach the line that reads Finalise Disc. Then press OK and then press OK a second time to confirm the action.
The documentation for the DVDR3330H is available from Philips here: . See page 52 for the screen captures. The Finalise steps are on page 53.
I hope this helps.
Aug 19, 2012 | Philips DVDR3330H DVD Player/HDD Recorder
I have successfully recorded from camcorder on to disc on my Samsung SH893M machine. But can you please tell me how to record from video tape to a dvd disc.
you need to connect your wire to VCR out put and connect the other side to DVD input don't forget yellow to yellow, red to red and white to white if you have 3 prongs wire.
Jun 07, 2011 | Samsung Televison & Video
How can I play a Region 1 Dvd in Australia?
power on the tv and dvd without any dvd in tray
open disc tray
press pause then 0000000 on remote
region menu shows on tv screen
select ur region
press pause on remote
then power off
Jan 26, 2010 | LG RH177 DVD Recorder/HDD Recorder
I have a hdd/dvd recorder model rh7880/rh7500 set timer recording to record onto dvd, machine switched itself on as normal but did not start to record and froze up.cannot get anything to respond either...
Recorder wasn't under warranty, so opened the unit up removed the dvd - rw disc ,which was corrupted as it turns out, put the machine back together switched it on and it worked perfectly.I have since tested it by recording both on to dvd,hdd and used the dubbing format and have had no problems.In the future I would recommend bying only top quality discs as it seems a dodgy one was responsible.
Jun 29, 2008 | LG Televison & Video
Recording from DVD recorder to disc
1) Put a compatible DVD in the tray. (I have noticed that I must format DVD+R discs, but others are formatted okay for recording -- such as DVD-R and DVD RW)
2) Close the tray.
3) Make sure the player is set to HDD and not to DVD. It will indicate HDD, DVD, or SD on the LCD screen.
4) Using the remote press the "functions" button.
5) Select "copy" from the menu when it appears.
6) You will now see the list of programs you have recorded to the HDD. Highlight the one you want to copy and press "Enter" on the remote.
7) I think there are two confirmation screens that come up, press start or continue or whatever it says.
8) My recorder generally takes about 14 minutes at high speed to copy a two-hour program. If the program is longer than 2- hours, you must divide it into tow or more shorter segments for more than one DVD.
9) If you want to select several shorter programs (not to exceed 2-hours combined) highlight the programs individually pressing the PAUSE button on the remote. This places a check mark next to each of the programs. When you finish, press the enter button on the remote and go through the confirmations screens again.
10) If the DVD is nor rewritable, it will automatically run the "finalize" program. It takes about 3 minutes and runs after recording. This formats the DVD so that it can be played in non-Panasonic players. If it is a DVD-RW, they you must finalize it manually if you want to watch it on other types of players.
Hope this helps,
Mar 27, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Mar 02, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Please help
I have had that problem in the past and I just pushed the DVD or the VHS button at the top of the remote. Sometimes when it is in a different mode you can get the menu but can't scroll.
Jan 19, 2008 | Samsung DVD-VR357
Philips DVDR3450H
Put the DVD back into the drive...Then open the DVD menu by selecting the first tittle on the disc....Hold down the up arrow on the remote to make the "Editing menu" appear....Then select "Finalize Disc".
These instructions can be found on page 54 of the instruction book.
Dec 29, 2007 | Philips DVDR3450H DVD Recorder/HDD...
Dubbing rom hdd to dvd
All you have to do is select dvd on the remote (at the top). Then it should do it automatically. If it doesn't, go to menu, then setup, disk, format. That does the job.
Nov 17, 2007 | LG RH1999H DVD Recorder/HDD Recorder
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
