Question about Yamaha RX-V659 Receiver
Sync clock with yamaha RX-V659
Hi, i conect my yamaha rec with digidesign digi 003 rack with optical or coax (spdif) cable,.. but conection is establish, soud play just for 1/4 sec and sign PCM on yamaha display just light and turn off for1/4 sec too.
i think so yamaha has self  synchronization internal clock  and rack digi003 has too intwernal clock,.. ant this is problem.. i need set up one of them to "master" and another like a "slave" for good sync.... how can a get to yamaha "seecret or service" setup, where i seting this option ?
thank for your time
mayo
  • eventwave Jul 06, 2008
    Hi robotek
    thanks for trying to help.
    its not inportent if i use 48khz or 44.1khz... sesions in protools (digi003) have settings before i use postproductions for music - radio (44,1) or for movies (48khz),... and digital output automaticly is selected.
    if you think frequency of sync,  digi 003 use 48khz and  this is not possible to change, but i can change source of clock ... and select digi 003 like master or like slave,... internal /optical /spdif / world clock... but its dont work with RX-V659.
    but i find service manual for RX-V659, and in selfdiagnostic codes of receiver, is on position 16. IF STATUS (Input function status),..information of reproduction signal,.. from Pc or from DVD player is in code <4th byte> 10 = PCM ,
    and from protools digi 003 is in code <4th byte> 01 = Err
    i think, so signal from digi 003 is not standard for RX-V659 and looking like Error signal.
    In service mode RX-V659 signal play normally, but i think protection codes in RX-V659 prohibit play unknown signal in user mode.
    now is the question how delette prohibit code and which, or can i "learn" RX-V659 identify new type of signal and assign him PCM symbol ?
    its is possible loading new version of soft and is it solutions ?
    thanks for your time and sorry for my english :o)
    regards eventwave
    i try ewery digi input on yamaha... optical / spdif... DVD/ CD/ DVR/ DTV / AUX /....... 2/3/4/5/6... asign to ewery input .. and situation is the same... ithink maybe is problem in digi003... maybe is problem in firmware digi003, and update is solution.. a try send mail to digidesign support and a send you info.
    thanks for everithing
  • 1,512 Answers
Hi eventwave
Are you using the 48khz or 44.1 for you spdif output. check that you have the output correctly formatted or it will not sync correctly. You should not need to have clocks synced to get spdif to work.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jul 06, 2008
  • Graeme Ross
    Graeme Ross Jul 06, 2008
    ok, I get the problem a bit better, the receiver is perhaps looking for AC3 or SR-D encoding at 48khz, and will bounce any signals that are not. I am not aware of any solution for you that can sort this easily. Have you tried changing the digital input settings of the Yamaha to better match the output of digioo3, page 92 of the manual references these settings.
  • Graeme Ross
    hey sure man, avid have some excellent forum type support. Takes a bit of looking, but most problems that ever existed get solved by upgrades in both firm and hard ware. No chance of an upgrade to FixYa for my efforts:) Cheers mate. Let me know if you find a cure. I reckon you could hardwire an external master clock into the yamaha. I like hardware solutions to this sort of drama. Makes it a challenge. :)
Tip
When Using ADAT with Digidesign Interface (Fix pops & clicks)
When you connect a device (a lightpipe optical ADAT for example) to your audio interface such as the Digi 003 be sure to change the "Hardware" settings in the File Menu, from internal to optical, and ADAT for using for using an optical ADAT device, such as the M-Audio Octane. This will stop the pops and clicks that happen when the clocking is not set for ADAT.
on Dec 08, 2009 | Digidesign 003 Rack Firewire Audio...
Stopped working
when this happened to ours it was the conection cable it had failed,try replacing that .hope it helps
Jan 15, 2015 | Yamaha YAS-101 Front Surround Sound Bar...
My Digi 002 Rack is "Clicking" (the actual unit).
Hi
First thing to do is a hard reset. Merely unplug the power cord for 4 hours, then power up again.In order to dissipated the remaining current stored in the memory and disconnect all unit connected.
Regards:
votit
Feb 08, 2011 | Digidesign Digi 002 Rack FireWire Pro...
No sound from rear speakers with TV and DVD player
You also have to connect a SPDIF coax or optical from both the DVD player and from the STBox into the digital inputs on the rear of the receiver. And select them with the remote control.
Apr 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Feb 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
I plugged in my cable HDMI into my RX - V365 Yamaha reciever. and HDMI into my TV. I get video, but cannot get my attached (to reciever) speakers to play. Help
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
Nov 14, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Open Questions:
See all Yamaha RX-V659 Receiver Questions
Yamaha RX-V659 Receiver Logo
407 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
