Chapter 6. Examine the tapes before inserting them into any drive or robotic environment to make sure the leader pin is present and properly clipped in (page 13).
The '6' means the drive detected a drive or media error. With only the Single Character Display it can't get specific. Follow the directions except I would highly recommend you run a Clean Cart first.
Handle your media carefully and keep them from experiencing any changes in temperature or humidity, say, on that trip to Iron Mountain. Alway open the slide door on the cartridge to examine the leader's proper positon before you use the tape or especially before you introduce it into any robotic environment. Dropped tapes will jam in or kill tape drives, always in the middle of the night. An ounce of prevention.
Hello, just a guess, but maybe you're using an old cleaning tape that has no more cleaning cycles left in it. Can I suggest you try a brand-new cleaning tape? Regards, nicam49
Set for any unrecoverable write or positioning error where isolation is uncertain and failure could be due to a faulty tape cartridge or to faulty drive hardware.
clean the drive with a clean tape, change a new data tape and try again. if you recycle the drv, the alert will disappear.
When the drives Clean LED comes on, install a "Universal" LTO Cleaning tape, as these drives do not need routine cleaning. Only ever clean a LTO drive when it's requested, as the cleaning media itself is more abrasive than a standard tape.
This means that the drive was unable to determine the exact issue. See http://support.dell.com/support/edocs/stor-sys/110TLTO2/en/ug/trouble.htm for more information and other error codes
Hi. This is from Dells site regarding automatic ejection of tape once inserted:
The PowerVault 110T DLT VS160 Tape drive reads and writes DLTtape
VS1 cartridges. The PowerVault 110T DLT VS160 Tape drive can read - but
not write - DLTtape™ IV cartridges written using the DLT1/VS80 format. NOTE: The PowerVault 110T DLT VS160 Tape
drive automatically ejects any other cartridge types and any cartridges
whose format it cannot read. Make sure all cartridges that you want to use
for writing are DLTtape VS1 cartridges.
Perhaps your cartridge is improperly formatted or is of the incorrect type?
