PROBLEMA EN AJUSTAR EL CORTE DE LA ETIQUETA, CUANDO LA IMPRESORA SENSA LA ETIQUETA, ESTA QUE CORRIDA HACIA LA PARTE DE ATRAS DEL CABEZAL HACIENDO NECESARIO UN FEED PARA PODER CORTAR LA ETIQUETA
I recommend that you use the drivers from www.seagullscientific.com, they have the best drivers and let you adjust all the printer settings. Roberto Martinez
Your platen roller (the black rubber roller) isn't smooth in that spot. Maybe it has be nicked or cut there or has something stuck onto it. If it's cut you will have to replace it, otherwise try cleaning it with high percentage isopropyl alcohol.
hi
you need to change the font colour of your priter
== for this you can go to the properties of the printer and change the colour
= this may help you
= Good Luck
