Question about LG KU990 Viewty
Hi There - I have just purchased a HP iPAQ HX2410 and I am trying to load a programme but have run out or storage. I got a storage card - but can not seem to free up space on the PDA - Can you please help me?
Followed the instructions of my expert - just some of the actions took too long to leave the chat open for while I tried.
Posted on Jul 07, 2008
I bought 2 used ipaq hx2410 3 months ago on ebay. cant use them. one is working but is locked by hp protection tools, need password or answer to secret question, cant reach the seller again, the other has...
why mess with old non supported dead products?
why not buy 2 old smart phones, 1000x better.
ok ask at HP , they need a good laugh today.
IPAQ is dead every which way but sunday.
no service provider supports it nor MS. nor HP, but do ask.
welcome to real HP support (we are not)
https://h30434.www3.hp.com/
Aug 08, 2017 | HP iPAQ hx2410 Pocket PC
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
When i reinstall the Bios on my Ipaq Hx2410 is fail.
I think you've know already (as an experienced technician) that opening h/w case won't solve anything..
The normal BIOS write is about 20 min (or more), longer than that it could be a problem with ActiveSync or your PC connections.
I'm afraid the ROM chip cannot re-restore because flashing basically format and write your BiosRom chip. Just pray that doing "hard reset" will turn your 'tiny' IpaQ to come alive.
Mar 30, 2009 | HP iPAQ hx2410 Pocket PC
Ipaq hx2410
reinstall windows thats the best i've got...
May 18, 2008 | HP iPAQ hx2410 Pocket PC
What's max mem size for ipaq 1950
Mem cards are added as storage cards and do not add up to your iPaq RAM.
You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
Hope this helps.
Feb 16, 2008 | HP iPAQ rx1950 Pocket PC
Ipaq hx2410 beem?
On your iPAQ, locate a file you wish to beam. Tap and hold the stylus on the file, you should get an option to "Beam File" Make sure your fairly close with other device when beaming files.
Sep 14, 2005 | HP iPAQ hx2410 Pocket PC
Hx2410 general wi-fi questions
Have you been able to connect through your router at home? I'd get that set up and running first. Then doing it on the road will merely be variations on a familiar theme. If you've tried at home but it hasn't worked, let us know something about your home network (what kind of router? using security/encryption?), and about what you've already tried so we can try to help.
Sep 08, 2005 | HP iPAQ hx2410 Pocket PC
Storage Memory
memory card isn't really memory it's more like a disk drive. it's not like when you add memory to a PC and the new memory is automatically used. To make use of this card you need to transfer some of your larger files to the card.... You can move files from within the ipaq... Click and hold on file. Select Copy Click and hold Select Cut Navigate with File Explorer to the SD card.... Open File Explorer Select My device Now select SD Card You can create a new folder or select an existing folder Click on Edit at bottom of screeen. Select Paste. You can also move files directly from PC to Storage card...... While IPAQ is connected, go to My Computer, then double-click on Mobile Device, then double-click on Pocket PC. Now you will see your Storage Card, and you can use this just like a folder on your PC. You can create folders within it. You can click and drag files to it or to any of it's folders.
Sep 07, 2005 | HP iPAQ H4150 Pocket PC
LG KU990 Viewty Logo
27 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
