Question about Polaroid I533P Digital Camera
Polaroid i735 Camera won't turn on. Lens stuck.
Batteries have been replaced.
Screen black.
Pressed power on button and camera beeps twice, then shuts off.
Lens stuck; won't retract.
Please help.
  • Anonymous Nov 09, 2008
    Camera wont turn on.
    black screen,
    turns of, beeps twice
    the shuts off.
Try ENERGIZER BATTERIES!!!!!!
Posted on Oct 29, 2008
I had the same problem, and fixed it by wiggling the lens a little, when turning it on.
After a few tries, it finally wiggled free, and the lens retracted.
Posted on Sep 11, 2008
My camera makes a chirping noise when i try to turn it on. it sounds like the battery is dead. i bought new batteries and same result.please help me figure out what is wrong with my camera.
You are facing this problem ,because the lens is stuck from inside . The iris is struck and you hear this chirping noise.
Carefully inspect around the lens for dirt or debris.
If you see any dirt or debris around the lens, use canned air to gently blow it away and turn on your camera.
Hope this helps.
Do rate the solution if it had helped you .
Thanks for using Fixya.
Shane
Dec 06, 2009 | Polaroid i735 Digital Camera
"Lens error, restart camera"
change the lens cover and change the battery please vote
Nov 04, 2009 | Canon PowerShot A1100 IS Digital Camera
Polaroid i735 lens stuck, three beeps and there is no sounds of the camera trying to do anything. The camera was barely 2 months used and never dropped...I have tried rechargeable and new alkaline...
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards iversh
if you felt i've spent my time for u... a very helpful rating is appreciated...
Aug 26, 2009 | Polaroid i735 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Polaroid i735 camera
you have to get rechargable batteries, they work great in it.
Jan 09, 2009 | Polaroid i735 Digital Camera
Camera Trouble
Check your batteries. If it is not the batteries then it is the power board of the camera
Dec 31, 2008 | Polaroid i735 Digital Camera
My camera wont stay on even with new batteries
I Have The Same Exact Camera As You And Have lost of Experience With Digital Cameras I'm Guessing you just need digital camera compatible batteries (Rechargeable) Oh and keep in mind taking a picture requires a lot of energy use
Dec 30, 2008 | Polaroid i735 Digital Camera
I733 DIGITAL CAMERA WOULNT TURN ON...
my camera started to say the screen said the batteries needed to be replaced can u help ME
Feb 28, 2008 | Polaroid i733LP Digital Camera
I733 Polaroid camera will not turn on
well I HAD THE SAME PROBLEM ALL I GOT WAS A BLACK SCREEN & 3 BEEPS,SO GOT A LETTER OPENER AND STUCK IT IN THE SPACE BETWEEN THE ZOOM LENS A FEW TIME VERY CAREFUL PUSHING DOWN THE POWER BUTTON AT THE SAME TIME AFTER A FEW TIMES THE LENS BECAME UNSTUCK..JUST JIGGLE IT A ROUND A LITTLE BACK AND FORTH WITH A LITTLE FORCE.I HOPE YOUR CAMERA WILL START TO WORK AGAIN LIKE MINE DID.
Jan 12, 2008 | Polaroid i733LP Digital Camera
Polaroid I533P Digital Camera Logo
290 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
