Security code for Renault / Philips 22DC277/62?
2004 Renault Megane Radio showing error after a new battery.
The barcode number: 8200256141TV110
V110 SECURITY
RN277F40500982
The radio will have to be removed from the car dashboard . Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING. Also quote the MAKE of CAR it is fitted into.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Please
quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL
CASING. There
should be a 14 character Serial Number beginning with RG or RN or PH or similar
(often found stamped in the metal casing ) and maybe a Security Number in the format of
TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING
you can find
It is either the wrong code or you are entering it incorrectly.
To get the code checked
POST
ANOTHER QUESTION
quoting
the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or
A
Renault normally has a 14 character Serial Number beginning with
RN++++++++++++
plus a Security Code in the format TOX123 or TX123 or just X123 at the
end of a barcode ...so please quote EVERYTHING you can find.
The code entry instructions for a Renault / Philips radio are
Philips Renault Code Entry Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ¬] button then rotate the thumb wheel for the
correct first digit Press the [ ¬] button then rotate the thumb wheel for the
correct second digit Press the [¬ ] button then rotate the thumb wheel for the
correct third digit Press the [ ¬] button then rotate the thumb wheel for the
correct fourth digit If the correct code
is now shown on screen
If you require a code the radio will have to be removed from the car dashboard . Then please POST A NEW QUESTION quoting the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING. ================================================ If your radio is a RENAULT/PHILIPS then here are the correct Code Entry Instructions
Press the [¬ ] button then rotate the thumb wheel for the correct first digit Press the [¬ ] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen, press and hold the [¬ ] button for up to 10 seconds to store the code
