Question about Fuji FinePix Z100fd Digital Camera
Copying the internal images to a memory card
I am trying to copy the images on my internal memory onto my memory card and I see the option to do it when the cards not in there but then when you try and do it it asks for the card and you cant open the part to put the card in with it shutting the camera off
    President:
  • 423 Answers
Put card in camera and press the playback button. Press menu and go down to the copy command. Press the right arrow and highlight the internal to memory card option. Press the right arrow to perform the transfer, and that ought to do it.
Posted on Jul 08, 2008
I can't view images on Internal memory when SD card is inserted.
Put the card in, then select "Copy" from the playback menu. You will then be given the option of copying individual images or all of them. See the instructions beginning on page 99 of the manual: http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s5700_s700_s5800_s800_manual_01.pdf
Jul 11, 2013 | Cameras
Tip
If your camera will not read or transfer internal images on to memory card
When your camera will not transfer images onto memory card this is often because the image storage has been set to 'Auto'. You need to set it back to internal memory temporarily to allow you to copy the images over to the card. Once you have done this you can set the camera back to 'Auto' and this will reset the system and you will now have access to all of the images on the card.
This particular procedure works with all cameras but the steps outlined here are for Kodak in particular.
Please follow these steps;
1) Insert the card
2) Turn the camera to Auto
3) Press review - "reading memory card"
4) Press menu and scroll down to image storage and press ok
5) Select Internal Memory and press OK
6) Scroll down to Copy - Copy Pictures to memory card
7) Scroll down to ALL and press OK - you should see "Copying" displayed
8) When the screen goes back to the main menu - Scroll to Image storage again and select Auto - OK - "Reading memory card"
You should now be able to see the pictures from your internal memory saved onto your memory card and your camera is once again ready to use.
Hope this helps. Please do register your vote using the Yes/No buttons below to reflect the helpfulness of this Tip.
on Dec 22, 2009 | Cameras
How to transfer internal memory to memory. When I inserted the card, the images became 0.
I'm sorry for the difficulties you're experiencing in copying images from Internal Memory to the Memory Card. Unfortunately, COPY option is not available in DSCT700.
You may connect the Camera to Computer after removing the Memory Card to transfer images from Internal Memory to Computer. And then insert the Memory Stick and transfer back to Camera to copy the images to Memory Stick.
Only few Cameras do not have the COPY option. Unfortunately, you're one of the victim.
You can confirm the information from the Handbook of the Camera.
Click hear to download the Handbook for the Camera.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 06, 2011 | Sony Cyber-shot DSC-T700 Digital Camera
How do I change from internal memory to external memory on my camera?
You can copy all the images from the Internal Memory to a Memory Stick Duo media using the COPY option in the Memory Stick Tool Menu option.
Please insert the Memory Stick Duo media with sufficient free capacity into the Camera.
Select MENU--> Settings-->Memory Stick Tool-->COPY-->OK.
The original images in the Internal memory retain after copying. You may have to delete the contents of the internal Memory. Remove the Memory Stick media after copying, then format the internal memory. FORMAT in Internal Memory Tool.
You can only copy the images to the new folder created on the Memory Stick Duo which is created automatically. You cannot copy the images to a specific folder.
Thanks for using FixYa.
May 09, 2011 | Sony Cyber-shot W290 Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    How do i switch off internal memory
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
      After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 17, 2010 | Kodak EasyShare C613 Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
      1. Menu
      2. Cam settings
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    How to download pics. from my camera to my computer
    Question :
    Follow these steps:
    1. On the camera, press Review and then Menu.
    2. Select Image Storage.
    3. Change to Internal Memory.
    4. In the menu listing, scroll down to Copy, and select OK.
    5. Select a single picture, or select All.
    Once your pictures are transferred to the SD card it will be easy to transferre onto the computer.
    Dec 12, 2009 | Kodak Easyshare C813 Digital Camera
    SD CARD
    If I remember correctly, when you insert an SD card, it "hides" the camera's internal memory. There should be an camera option for copying the files from the internal memory onto the inserted SD card. If not, you could try connecting the camera to your computer with the SD card removed, in order to access the files in the internal memory.
    Feb 10, 2007 | Samsung Digimax S500 Digital Camera
    Can I move images saved to the internal memory to the optional xD-Picture Card?
    You sure can. Go to your shooting mode menu. Scroll down to BACKUP Click on OK Select YES Click on OK All image data stored in the internal memory is copied to the card. Press MENU to exit the menu. Make sure there is enough room on your card to hold all the pictures in memory. When you've copied to the card the original pictures are still held in the internal memory so you will have to clear it. When the card has insufficient memory, [CARD FULL] is displayed and copying is canceled. When the battery icon is blinking, pictures cannot be backed up because of insufficient battery power. If the battery power runs out during copying, the image data may be lost or damaged. I recommended you use the AC adapter if you have one. If not, make sure your batteries are charged. Never open the battery compartment/card cover, remove the batteries, or connect or disconnect the AC adapter during copying as this may cause malfunction to the internal memory or the card.
    Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
    Fuji FinePix Z100fd Digital Camera Logo
    78 people viewed this question
    Top Fuji Cameras Experts
    Greg Cann
    Greg Cann
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
